MantisBT - ParaView |
View Issue Details |
0015648 | ParaView | (No Category) | public | 2015-08-13 14:54 | 2015-12-01 17:16 |
Reporter | Ken Moreland | |
Assigned To | Cory Quammen | |
Status | closed | Resolution | fixed | |
Product Version | git-master | |
Target Version | 4.4 | Fixed in Version | 4.4 | |
Project | Sandia |
Topic Name | 15648_update_find_data_dialog |
Type | incorrect functionality |
Summary | 0015648: Find Data fields not initially updated correctly after session reset. |
Description | The Find Data dialog box is not initially populating the field chooser box with all the cell fields after Reset Session is run. To replicate do the following:
1. Open can.ex2. Load all variables. Apply.
2. Open the Find Data dialog box.
3. Close the Find Data dialog box.
4. Edit -> Reset Session
5. Open can.ex2. Load all variables. Apply.
6. Open the Find Data dialog box.
By default, the upper left combo box is set to find cells. The combo box below that is supposed to be populated with all the cell fields that you can query on. But initially it only has ID and Query. Where are EQPS, GlobalElementId and the others?
You can work around this bug by changing the upper left combo box from Cells to Points and then back to Cells. That seems to cause the combo boxes to update. (Although for some reason the block query line disappears. Maybe you should have a query specifically on blocks?) |
Steps To Reproduce | |
Additional Information | |
Tags | No tags attached. |
Relationships | related to | 0015650 | closed | Cory Quammen | Show frustum toggle not working after reset session |
Attached Files | |
2015-08-13 14:54 | Ken Moreland | New Issue | |
2015-08-13 17:57 | Ken Moreland | Relationship added | related to 0015650 |
2015-08-17 16:14 | Alan Scott | Project | TBD => Sandia |
2015-08-17 16:14 | Alan Scott | Note Added: 0035007 | |
2015-08-17 16:14 | Alan Scott | Status | backlog => todo |
2015-08-17 16:14 | Alan Scott | Target Version | => 4.4 |
2015-08-19 09:06 | Utkarsh Ayachit | Note Added: 0035029 | |
2015-08-27 22:28 | Cory Quammen | Assigned To | => Cory Quammen |
2015-08-27 22:37 | Cory Quammen | Status | todo => active development |
2015-08-31 00:16 | Cory Quammen | Note Added: 0035101 | |
2015-09-02 17:41 | Cory Quammen | Topic Name | => 15648_update_find_data_dialog |
2015-09-02 17:41 | Cory Quammen | Note Added: 0035141 | |
2015-09-02 17:41 | Cory Quammen | Status | active development => gatekeeper review |
2015-09-02 17:41 | Cory Quammen | Fixed in Version | => 4.4 |
2015-09-02 17:41 | Cory Quammen | Resolution | open => fixed |
2015-09-03 09:38 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2015-12-01 17:16 | Alan Scott | Note Added: 0035499 | |
2015-12-01 17:16 | Alan Scott | Status | customer review => closed |
(0035007)
Alan Scott
2015-08-17 16:14
Find data is important. Unless difficult or risky, lets try to get this into 4.4. |
(0035029)
Utkarsh Ayachit
2015-08-19 09:06
Another issue (potentially related):
+ Open can.ex2 (don't hit Apply)
+ Open Find Data dialog
+ Now select all variables on can.ex2 and hit Apply.
+ The Find Data dialog's fields are not updated. Changing the active source to the "builtin" and then back to can.ex2 in the Pipeline browser overcomes this issue. |
(0035101)
Cory Quammen
2015-08-31 00:16
(0035141)
Cory Quammen
2015-09-02 17:41
commit 79e0aebc8484422087fea83634722b3b7581cd44
Author: Cory Quammen <cory.quammen@kitware.com>
Date: Sun Aug 30 23:52:56 2015 -0400
BUG 15648: Update fields in find data dialog
In some cases, the field combo box would not be updated when showing
the Find Data dialog. Fixed things to update the field combo box when
the data is updated in the selected port's pipeline source. |
(0035499)
Alan Scott
2015-12-01 17:16
Tested with Ken and also Utkarsh's report. Linux, master, local server. |
