MantisBT - ParaView | |||||
View Issue Details | |||||
0015683 | ParaView | (No Category) | public | 2015-08-26 10:02 | 2016-08-12 09:59 |
Reporter | Vadim SANDLER | ||||
Assigned To | Joachim Pouderoux | ||||
Product Version | 4.3 | ||||
Project | ParaViS | ||||
Topic Name | |||||
Summary | 0015683: Extract bag plot filter does not use good criteria to choose outliers | ||||
Description | The identification of outliers should not be based on a limit of the density of the data points but on a decreasing sorting in density of points. In the Rainbow package of the R software, the algorithm used is the Hyndman one to identify high density regions. Computing and Graphing Highest Density Regions, Rob J. Hyndman, The American Statistician, Vol. 50, No. 2 (May, 1996), pp. 120-126 The ACP_classique.R script is using a classical PCA and does not use the Rainbow package. So those the result can be directly compared to Paraview with default parameters. The median curve is the number 15 et the only outlier is the 21. Those results can be used to build a simple unitary test. A more complicated one would compare the two PCA projections (execute the R script on the 2 first components). | ||||
Steps To Reproduce | |||||
Relationships | |||||
Attached Files | gaussiansine.csv (226,137) 2015-08-26 10:02 https://www.vtk.org/Bug/file/9889/gaussiansine.csv test.sce (821) 2015-08-26 10:02 https://www.vtk.org/Bug/file/9890/test.sce ACP_classique.R (3,005) 2015-08-26 10:03 https://www.vtk.org/Bug/file/9891/ACP_classique.R Gsine_hdrplot_outlier_bivariee.png (9,664) 2015-08-26 10:03 https://www.vtk.org/Bug/file/9892/Gsine_hdrplot_outlier_bivariee.png Gsine_hdrplot_outlier_fonctionnelle.png (10,762) 2015-08-26 10:03 https://www.vtk.org/Bug/file/9893/Gsine_hdrplot_outlier_fonctionnelle.png | ||||
Issue History | |||||
2015-08-26 10:02 | Vadim SANDLER | New Issue | |||
2015-08-26 10:02 | Vadim SANDLER | File Added: gaussiansine.csv | |||
2015-08-26 10:02 | Vadim SANDLER | File Added: test.sce | |||
2015-08-26 10:03 | Vadim SANDLER | File Added: ACP_classique.R | |||
2015-08-26 10:03 | Vadim SANDLER | File Added: Gsine_hdrplot_outlier_bivariee.png | |||
2015-08-26 10:03 | Vadim SANDLER | File Added: Gsine_hdrplot_outlier_fonctionnelle.png | |||
2016-03-03 08:41 | Joachim Pouderoux | Note Added: 0035816 | |||
2016-03-03 08:43 | Joachim Pouderoux | Assigned To | => Joachim Pouderoux | ||
2016-03-03 08:43 | Joachim Pouderoux | Status | backlog => active development | ||
2016-08-12 09:59 | Kitware Robot | Note Added: 0038876 | |||
2016-08-12 09:59 | Kitware Robot | Status | active development => closed | ||
Notes | |||||
