MantisBT - ParaView | |||||
View Issue Details | |||||
0015707 | ParaView | (No Category) | public | 2015-09-08 04:00 | 2016-08-12 09:59 |
Reporter | Mathieu Westphal | ||||
Priority | high | Severity | minor | Reproducibility | have not tried |
Product Version | git-master | ||||
Project | TBD | ||||
Topic Name | |||||
Summary | 0015707: "Find Data" Selection expansion error | ||||
Description | When selecting points or cells using the Find Data dialog, the resultant selection is not expandable, and trying to expand it will result the following warning : Generic Warning: In /home/glow/work/kitware/paraview/paraview/ParaViewCore/ServerManager/Core/vtkSMPropertyHelper.cxx, line 511 Failed to locate property: ContainingCells The selection is then lost. | ||||
Steps To Reproduce | Open paraview create a sphere, apply edit->FindData Id = 1 -> runQuery close select cells on "Ctrl" + selection | ||||
Additional Information | I tried to look into the issue, but i'm not sure of how responsible tu add this property to the selection source, and why find data selection does not have it. I do not understand what is the use of this property anyway. | ||||
Relationships | |||||
Attached Files | |||||
Issue History | |||||
2015-09-08 04:00 | Mathieu Westphal | New Issue | |||
2015-09-08 04:02 | Mathieu Westphal | Steps to Reproduce Updated | bug_revision_view_page.php?rev_id=1279#r1279 | ||
2015-09-08 04:02 | Mathieu Westphal | Additional Information Updated | bug_revision_view_page.php?rev_id=1281#r1281 | ||
2016-08-12 09:59 | Kitware Robot | Note Added: 0038885 | |||
Notes | |||||
