MantisBT - ParaView | |||||
View Issue Details | |||||
0015749 | ParaView | (No Category) | public | 2015-09-30 10:23 | 2016-08-12 09:59 |
Reporter | Joachim Pouderoux | ||||
Priority | normal | Severity | minor | Reproducibility | always |
Product Version | 4.4 | ||||
Target Version | 5.1 | Fixed in Version | |||
Project | TBD | ||||
Topic Name | |||||
Summary | 0015749: Spreadsheet view: toggling cell connectivity visibility does not always work | ||||
Description | When browsing cell data in the spreadsheet, it can be useful to see the cell connectivity. The button "{...}" is supposed to add columns in the table so display the cell to points connectivity information. However, if the feature works sometimes, some others it just does nothing. | ||||
Steps To Reproduce | Start ParaView. - Create two sources (eg. a Cone and a Cylinder) - Split the view and create a Spreadsheet view - Show the first source in the spreadsheet and select Cell Data attributes - Click on {...} to show the cell connectivity. It (might?) works. - Now show the second source in the spreadsheet and select its Cell Data. - Click on {...}, the connectivity columns are not created. It fails. | ||||
Relationships | |||||
Attached Files | |||||
Issue History | |||||
2015-09-30 10:23 | Joachim Pouderoux | New Issue | |||
2015-09-30 10:27 | Joachim Pouderoux | Steps to Reproduce Updated | bug_revision_view_page.php?rev_id=1323#r1323 | ||
2016-03-03 08:03 | Joachim Pouderoux | Reproducibility | have not tried => always | ||
2016-03-03 08:03 | Joachim Pouderoux | Target Version | => 5.1 | ||
2016-08-12 09:59 | Kitware Robot | Note Added: 0038900 | |||
Notes | |||||
