MantisBT - ParaView | |||||
View Issue Details | |||||
0015780 | ParaView | (No Category) | public | 2015-10-14 11:04 | 2015-10-14 12:27 |
Reporter | Christopher Neal | ||||
Assigned To | Alan Scott | ||||
Priority | urgent | Severity | minor | Reproducibility | have not tried |
Status | closed | Resolution | fixed | ||
Product Version | 4.3 | ||||
Project | TBD | ||||
Topic Name | |||||
Type | crash | ||||
Summary | 0015780: Paraview Crashes when loading state and trying to save an animation | ||||
Description | Hello, I have an Ensight Gold format data set that contains files for a set of timesteps. I have no issues with loading the data and performing a set of pipeline operations on the data. I saved my pipeline state to save time when loading other data sets that would require the same operations. The state file saves without an issue. When I open up paraview 4.3.1 again and load state I get a dialog box that asks me for the path to the ensight data file. I give it a path to a particular data set and it loads. It doesn't seem to be loading the other timesteps when it loads from the state file. When I try to save an animation it crashes before I can see anything on the error terminal. I'm running on Windows 7 64 bit. Note: I also tried it with Paraview 4.4.0 and it still isn't loading the timesteps correctly when loading the ensight data set from the state file. I have attached a minimal working example that has 3 timesteps worth of data and the state file that I used when it crashed. It is somewhat important because it will be tedious to have to perform the pipeline operations for every data set that I want to animate. Thank you, Chris Neal | ||||
Steps To Reproduce | |||||
Relationships | |||||
Attached Files | jetl_ensight_State_Crash_Test.zip (3,545,783) 2015-10-14 11:04 https://www.vtk.org/Bug/file/9927/jetl_ensight_State_Crash_Test.zip | ||||
Issue History | |||||
2015-10-14 11:04 | Christopher Neal | New Issue | |||
2015-10-14 11:04 | Christopher Neal | Assigned To | => Alan Scott | ||
2015-10-14 11:04 | Christopher Neal | File Added: jetl_ensight_State_Crash_Test.zip | |||
2015-10-14 11:20 | Christopher Neal | Note Added: 0035285 | |||
2015-10-14 12:27 | Alan Scott | Note Added: 0035287 | |||
2015-10-14 12:27 | Alan Scott | Status | backlog => closed | ||
2015-10-14 12:27 | Alan Scott | Resolution | open => fixed |
Notes | |||||
