MantisBT - ParaView | ||||||||||
View Issue Details | ||||||||||
ID | Project | Category | View Status | Date Submitted | Last Update | |||||
0015789 | ParaView | (No Category) | public | 2015-10-19 02:55 | 2016-08-12 09:59 | |||||
Reporter | Menno Deij | |||||||||
Assigned To | Kitware Robot | |||||||||
Priority | normal | Severity | minor | Reproducibility | have not tried | |||||
Status | closed | Resolution | moved | |||||||
Platform | OS | OS Version | ||||||||
Product Version | 4.4 | |||||||||
Target Version | Fixed in Version | |||||||||
Project | TBD | |||||||||
Topic Name | ||||||||||
Type | feature | |||||||||
Summary | 0015789: Array selection on .vtm multi-block reader | |||||||||
Description | I noticed that when I load a .vtm file, I cannot select which data fields to load. This requires me to load the entire file into memory, after which the Pass Arrays filter allows me to take the required data field forward in the pipeline. If I load other formats (e.g. CGNS and .vtu) I can choose which field to load. It would be very nice if this can be added. Comment from the discussion in the mailing list by Andy Bauer: "Multiblock data sets aren't required to have the same fields defined over all of the blocks. That doesn't necessarily mean this can't be done, it just means it may not be quite as straightforward and/or clear as for the data set readers." I have seen in ParaView that an array can also be "Partial". Maybe that is also the solution in this case? | |||||||||
Steps To Reproduce | ||||||||||
Additional Information | ||||||||||
Tags | No tags attached. | |||||||||
Attached Files | ||||||||||
Issue History | ||||||||||
Date Modified | Username | Field | Change | |||||||
2015-10-19 02:55 | Menno Deij | New Issue | ||||||||
2015-10-19 10:01 | Cory Quammen | Relationship added | duplicate of 0015768 | |||||||
2016-08-12 09:59 | Kitware Robot | Note Added: 0038911 | ||||||||
2016-08-12 09:59 | Kitware Robot | Status | backlog => closed | |||||||
2016-08-12 09:59 | Kitware Robot | Resolution | open => moved | |||||||
Notes | |||||
