MantisBT - ParaView | |||||||||||||||
View Issue Details | |||||||||||||||
ID | Project | Category | View Status | Date Submitted | Last Update | ||||||||||
0015917 | ParaView | (No Category) | public | 2016-01-05 18:34 | 2016-08-12 09:59 | ||||||||||
Reporter | Alan Scott | ||||||||||||||
Assigned To | T.J. Corona | ||||||||||||||
Priority | normal | Severity | minor | Reproducibility | have not tried | ||||||||||
Status | closed | Resolution | moved | ||||||||||||
Platform | OS | OS Version | |||||||||||||
Product Version | 5.0 | ||||||||||||||
Target Version | 5.1 | Fixed in Version | |||||||||||||
Project | Sandia | ||||||||||||||
Topic Name | |||||||||||||||
Type | incorrect functionality | ||||||||||||||
Summary | 0015917: Change max timestep display to make sense | ||||||||||||||
Description | Please change the time toolbar, maximum timestep section (that currently says "of ##") to be zero based. In other words, make this N-1, rather than N. Furthermore, change the verbiage to say "max is ###". For can.exo, it currently says "of 44". Make it "max is 43". In the Animation View: * When the mode is Snap To Timesteps, please update the No. Frames. * When the mode is Snap to Timesteps, please don't gray out the Time and No. Frames box. * Fix the bug where you change Mode to Realtime, then back to Snap to Timesteps, and the label No. Frames does not appear. * Fix the bug where you change Mode to Realtime, then back to Snap to Timesteps, and labels are not grayed out correctly. You should see (in black) Time and No. Frames), Start Time and End Time should be grayed out. | ||||||||||||||
Steps To Reproduce | |||||||||||||||
Additional Information | |||||||||||||||
Tags | No tags attached. | ||||||||||||||
Attached Files | |||||||||||||||
Issue History | |||||||||||||||
Date Modified | Username | Field | Change | ||||||||||||
2016-01-05 18:34 | Alan Scott | New Issue | |||||||||||||
2016-01-05 18:34 | Alan Scott | Product Version | => 5.0 | ||||||||||||
2016-01-05 18:34 | Alan Scott | Target Version | => 5.1 | ||||||||||||
2016-01-05 18:35 | Alan Scott | Relationship added | related to 0015062 | ||||||||||||
2016-01-05 18:37 | Alan Scott | Relationship added | has duplicate 0015915 | ||||||||||||
2016-07-06 12:45 | T.J. Corona | Assigned To | => T.J. Corona | ||||||||||||
2016-07-06 12:45 | T.J. Corona | Status | backlog => active development | ||||||||||||
2016-07-06 12:45 | T.J. Corona | Resolution | open => fixed | ||||||||||||
2016-07-18 18:21 | T.J. Corona | Note Added: 0036527 | |||||||||||||
2016-07-18 18:23 | T.J. Corona | Note Added: 0036528 | |||||||||||||
2016-08-12 09:59 | Kitware Robot | Note Added: 0038963 | |||||||||||||
2016-08-12 09:59 | Kitware Robot | Status | active development => closed | ||||||||||||
2016-08-12 09:59 | Kitware Robot | Resolution | fixed => moved |
Notes | |||||
