MantisBT - ParaView | |||||
View Issue Details | |||||
0015943 | ParaView | (No Category) | public | 2016-01-19 21:01 | 2016-08-12 09:59 |
Reporter | Antu Xie | ||||
Product Version | 5.0 | ||||
Project | TBD | ||||
Topic Name | |||||
Summary | 0015943: Filtering by property with at least one space in it returns an error | ||||
Description | If you attempt to use the selection filter (Edit -> Find Data), and the property you want to filter on has a space in the name, the property will fail. I frequently encounter this when importing from a UCD format unstructured grid, as the name is defaulted to be "Material Id" with no way of changing it. The only workaround I've found for this is to first save the data as something else (vtk), change the name to be "MaterialId" in a text editor, and then open it again in Paraview. I have attached an AVS UCD file, MeshOutput.inp, for reference. A special thank you to whoever thinks they can take a look at this. | ||||
Steps To Reproduce | |||||
Relationships | |||||
Attached Files | MeshOutput.inp (2,930) 2016-01-19 21:01 https://www.vtk.org/Bug/file/10003/MeshOutput.inp | ||||
Issue History | |||||
2016-01-19 21:01 | Antu Xie | New Issue | |||
2016-01-19 21:01 | Antu Xie | File Added: MeshOutput.inp | |||
2016-08-12 09:59 | Kitware Robot | Note Added: 0038978 | |||
Notes | |||||
