MantisBT - ParaView | |||||
View Issue Details | |||||
0015950 | ParaView | (No Category) | public | 2016-01-20 17:19 | 2016-08-12 09:59 |
Reporter | Alan Scott | ||||
Assigned To | Nathan Fabian | ||||
Product Version | 5.0 | ||||
Project | Sandia | ||||
Topic Name | |||||
Summary | 0015950: Exodus writer - edge sets not written correctly, | ||||
Description | A customer is having issues writing edge sets, coming from the Resample with Dataset filter. Here is how to replicate: * Open donor-DoNotRelease.g. All variables on. Apply. * Note - Two important vars - PRES_PA and TEMP_K * Open recipient-DoNotRelease.g. Select Has Mode Shapes. Advanced Properties tab. Select all Sets. Select all Variables. Apply. * Note - PRES_PA and TEMP_K do not exist in this dataset. * Resample with Dataset. ** Input > donor-DoNotRelease.g ** Source > recipient-DoNotRelease.g OK. * (Advanced properties need to be on.) * select Pass Cell Array, select Pass Point Array. * unselect Compute Tolerance. Set manual tolerance to 1e-3. * Apply * Note - ResampleToDataset should already be selected. If not, select it. * Save Data. Exodus file. Save as some known file, such as combined-DoNotRelease.e. Don't save all timesteps - it will take forever. * Now, open combined-DoNotRelease.e. All variables on, all sets on, all blocks off. There's nothing here! This is a bug. | ||||
Steps To Reproduce | |||||
Relationships | |||||
Attached Files | |||||
Issue History | |||||
2016-01-20 17:19 | Alan Scott | New Issue | |||
2016-01-26 17:03 | Alan Scott | Assigned To | => Nathan Fabian | ||
2016-01-26 17:09 | Alan Scott | Note Added: 0035680 | |||
2016-08-12 09:59 | Kitware Robot | Note Added: 0038982 | |||
Notes | |||||
