MantisBT - ParaView | ||||||||||||||||||||
View Issue Details | ||||||||||||||||||||
ID | Project | Category | View Status | Date Submitted | Last Update | |||||||||||||||
0015984 | ParaView | (No Category) | public | 2016-02-09 15:39 | 2016-07-25 20:54 | |||||||||||||||
Reporter | Alan Scott | |||||||||||||||||||
Assigned To | Sujin Philip | |||||||||||||||||||
Priority | normal | Severity | minor | Reproducibility | have not tried | |||||||||||||||
Status | closed | Resolution | fixed | |||||||||||||||||
Platform | OS | OS Version | ||||||||||||||||||
Product Version | 5.0 | |||||||||||||||||||
Target Version | 5.1 | Fixed in Version | git-master | |||||||||||||||||
Project | Sandia | |||||||||||||||||||
Topic Name | ||||||||||||||||||||
Type | incorrect functionality | |||||||||||||||||||
Summary | 0015984: Clip and slice by cylinder is broken | |||||||||||||||||||
Description | Numerous aspects of the clip and slice by cylinder are broken. Here is how to replicate: * 5.0.0, Linux, local server. * Open disk_out_ref.exo, all vars on, apply. * Slice. Slice type, Cylinder. Apply. <<Bug>> Notice that we now have a cylinder widget. Sweet. However, the red rings represent where the cylinder should be. We are perpindicular to that. In other words, the cylinder widget goes down the X axis, the default cylinder goes down the Y axis. You can see this by moving the cylinder tool and hitting apply. * Reset the Cylinder slice. Easiest way is to delete the filter and recreate. <<Bug>> Change the Axis Y to 0, preparing to set the Axis Z to 1. A warning message comes up - but you haven't hit apply yet! * Change the center to be 0, 0, 0. Now, try setting it to 1,0,0. This works. Try 4,0,0 then 5,0,0 then 6,0,0 then 6.5,0,0 then 7,0,0. Keep hitting apply. <<Bug>> When against the edge of the cylinder tool bounding box, the cylinder tool separates from the slice. * Change the center to be 10, 0, 0. Apply. <<Bug>> We get an error message saying "No prominent values for consumer.". Please give a better error message, something like Trying to slice outside of the object, or somesuch. By the way, we get this error message for slice by plane also. | |||||||||||||||||||
Steps To Reproduce | ||||||||||||||||||||
Additional Information | ||||||||||||||||||||
Tags | No tags attached. | |||||||||||||||||||
Attached Files | ||||||||||||||||||||
Issue History | ||||||||||||||||||||
Date Modified | Username | Field | Change | |||||||||||||||||
2016-02-09 15:39 | Alan Scott | New Issue | ||||||||||||||||||
2016-02-09 15:39 | Alan Scott | Relationship added | related to 0015579 | |||||||||||||||||
2016-02-09 15:39 | Alan Scott | Target Version | => 5.1 | |||||||||||||||||
2016-02-09 15:42 | Alan Scott | Relationship added | related to 0015985 | |||||||||||||||||
2016-05-06 16:52 | Sujin Philip | Relationship added | related to 0016112 | |||||||||||||||||
2016-05-06 16:53 | Sujin Philip | Note Added: 0035935 | ||||||||||||||||||
2016-07-12 11:40 | Utkarsh Ayachit | Note Added: 0036337 | ||||||||||||||||||
2016-07-12 11:43 | Sujin Philip | Note Added: 0036338 | ||||||||||||||||||
2016-07-12 11:52 | Utkarsh Ayachit | Assigned To | => Sujin Philip | |||||||||||||||||
2016-07-12 11:52 | Utkarsh Ayachit | Status | backlog => customer review | |||||||||||||||||
2016-07-12 11:52 | Utkarsh Ayachit | Resolution | open => fixed | |||||||||||||||||
2016-07-12 11:52 | Utkarsh Ayachit | Fixed in Version | => git-master | |||||||||||||||||
2016-07-25 20:54 | Alan Scott | Note Added: 0036574 | ||||||||||||||||||
2016-07-25 20:54 | Alan Scott | Status | customer review => closed |
Notes | |||||
