MantisBT - ParaView |
View Issue Details |
0015997 | ParaView | (No Category) | public | 2016-02-12 20:41 | 2016-06-09 10:58 |
Reporter | Alan Scott | |
Assigned To | Utkarsh Ayachit | |
Status | closed | Resolution | fixed | |
Product Version | 4.4 | |
Target Version | 5.1 | Fixed in Version | 5.1 | |
Project | Sandia |
Topic Name | |
Type | incorrect functionality |
Summary | 0015997: PLY writer and/or reader is broken. |
Description | The PLY writer and/or reader is broken. Here is how to replicate:
* 4.4.0, local server, Linux.
* Load z_pinch1.8.[0-7]. All vars on. Apply. (Ask Utkarsh for this file set.)
* Go to last timestep. Paint by J.
* Filters/ Extract Surface. Apply.
* File / Save Data/ ply. Write this file somewhere.
* Edit/ Reset Session.
* Load Ply file. It won't have correct colors - everything will be white. Be sure to try to color by a variable.
Steps To Reproduce | |
Additional Information | |
Tags | No tags attached. |
Attached Files | |
2016-02-12 20:41 | Alan Scott | New Issue | |
2016-02-18 09:11 | Cory Quammen | Note Added: 0035751 | |
2016-02-19 13:33 | Alan Scott | Note Added: 0035755 | |
2016-02-19 13:34 | Alan Scott | Note Added: 0035756 | |
2016-02-22 17:44 | Alan Scott | Note Added: 0035761 | |
2016-02-22 17:44 | Alan Scott | Target Version | => 5.1 |
2016-03-01 12:50 | Alan Scott | Note Added: 0035804 | |
2016-03-30 15:45 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2016-03-30 15:45 | Utkarsh Ayachit | Status | backlog => active development |
2016-03-31 16:16 | Utkarsh Ayachit | Note Added: 0035868 | |
2016-03-31 16:16 | Utkarsh Ayachit | Status | active development => gatekeeper review |
2016-03-31 16:16 | Utkarsh Ayachit | Resolution | open => fixed |
2016-03-31 16:26 | Utkarsh Ayachit | Note Added: 0035869 | |
2016-03-31 16:27 | Utkarsh Ayachit | Note Edited: 0035869 | bug_revision_view_page.php?bugnote_id=35869#r1559 |
2016-03-31 21:15 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2016-03-31 21:15 | Utkarsh Ayachit | Fixed in Version | => git-master |
2016-04-15 22:17 | Alan Scott | Note Added: 0035892 | |
2016-04-15 22:17 | Alan Scott | Status | customer review => closed |
2016-06-09 10:58 | Utkarsh Ayachit | Fixed in Version | git-master => 5.1 |
(0035751)
Cory Quammen
2016-02-18 09:11
Alan,
The PLY format is not general enough to save point or cell data. It does support point colors, and it should be possible to export colors mapped through the current lookup table with some work.
However, when you load the PLY, it will not have the original variables by which you could color. It will be limited to either solid color or the colors on the surface as they appeared when the file was saved.
Would you like to have the functionality of saving the colors in the PLY file? |
(0035755)
Alan Scott
2016-02-19 13:33
Yes, I would like the functionality you describe - adding the ability to save the surface color of the object - into PLY files. You are correct - this file format does not include variable arrays, only surface color at the time the file was saved. |
(0035756)
Alan Scott
2016-02-19 13:34
(0035761)
Alan Scott
2016-02-22 17:44
Needed to create products to be ingested by slycat. |
(0035804)
Alan Scott
2016-03-01 12:50
I have another user trying to use this. Processing the output of the new CTH contour functionality. |
(0035868)
Utkarsh Ayachit
2016-03-31 16:16
MR: https://gitlab.kitware.com/paraview/paraview/merge_requests/713 [^]
BUG 0015997: Add ability to save color information in PLY files.
The PLY writer now allows user to choose whether color information is to
be saved in the output file. When enabled, ParaView uses the data
sources coloring state in the active view i.e. the array to color with
and the LUT to use, to pass along to the writer so that it can save RGB
color values in the output dataset. |
(0035869)
Utkarsh Ayachit
2016-03-31 16:26
(edited on: 2016-03-31 16:27) |
Note that on reloading the PLY file in ParaView, ParaView will by default use a color map for coloring and hence the color will look different. Uncheck "Map Scalars" and you'll see the RGB colors saved in the PLY file which should match the color map used when saving the PLY file.
(0035892)
Alan Scott
2016-04-15 22:17
Yes, I believe that is what the user wanted. Nice, thanks.
Tested local server, master, Linux. |
