MantisBT - ParaView | |||||
View Issue Details | |||||
0016005 | ParaView | (No Category) | public | 2016-02-18 15:06 | 2016-08-12 10:00 |
Reporter | Alan Scott | ||||
Product Version | 5.0 | ||||
Target Version | 5.0.1 | Fixed in Version | |||
Project | Sandia | ||||
Topic Name | |||||
Summary | 0016005: Trace recorder fails for CTH data | ||||
Description | The trace recorder fails for CTH data. I am going to create two sections for this bug - what is currently failing, and the test that needs to work, when this first bug is fixed. Current bug: * 5.0.0, Linux, local server. * Start trace. * Open Dave's small CTH dataset (four files). All vars on. Apply. * Optionally, you may want to turn visibility off in the pipeline browser for Markers and Tracers. * Stop trace. * Save as macro (or any other script). * Edit/ Reset Session. * Run macro. You will not get anything to show on the screen, and will get the following output: Traceback (most recent call last): File "<string>", line 39, in <module> NameError: name 'OutputPort' is not defined Further, if you had gotten farther with your script, you would see nothing at all after this point (such as if you had run a filter). OK, what should work? Here is a bare minimum: * 5.0.0, Linux, local server. * Start trace. * Open Dave's small CTH dataset (four files). All vars on. Apply. * Optionally, you may want to turn visibility off in the pipeline browser for Markers and Tracers. * Extract CTH Parts. Material Volume Fraction - 1 only. Apply. * Select Volume data in the pipeline browser. * Extract CTH Parts. Material Volume Fraction - 2 only. Apply. * Paint by pressure. * Stop trace. * Save as macro (or any other script). * Edit/ Reset Session. * Run macro. | ||||
Steps To Reproduce | |||||
Relationships | |||||
Attached Files | badOpenCTHFile.py (2,659) 2016-02-24 17:14 https://www.vtk.org/Bug/file/10051/badOpenCTHFile.py | ||||
Issue History | |||||
2016-02-18 15:06 | Alan Scott | New Issue | |||
2016-02-18 15:06 | Alan Scott | Target Version | => 5.0.1 | ||
2016-02-23 09:57 | Utkarsh Ayachit | Note Added: 0035766 | |||
2016-02-23 09:57 | Utkarsh Ayachit | Status | backlog => customer review | ||
2016-02-23 09:57 | Utkarsh Ayachit | Fixed in Version | => 5.1 | ||
2016-02-23 09:57 | Utkarsh Ayachit | Resolution | open => fixed | ||
2016-02-23 09:57 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit | ||
2016-02-24 16:30 | Alan Scott | Note Added: 0035775 | |||
2016-02-24 16:30 | Alan Scott | Status | customer review => todo | ||
2016-02-24 17:12 | Alan Scott | Note Added: 0035778 | |||
2016-02-24 17:14 | Alan Scott | File Added: badOpenCTHFile.py | |||
2016-02-24 17:22 | Utkarsh Ayachit | Note Added: 0035780 | |||
2016-02-24 17:23 | Utkarsh Ayachit | Status | todo => customer review | ||
2016-02-24 17:23 | Utkarsh Ayachit | Fixed in Version | 5.1 => 5.0.1 | ||
2016-02-24 17:29 | Alan Scott | Note Added: 0035782 | |||
2016-02-25 22:10 | Alan Scott | Note Added: 0035800 | |||
2016-02-25 22:10 | Alan Scott | Status | customer review => todo | ||
2016-08-12 10:00 | Kitware Robot | Note Added: 0039003 | |||
2016-08-12 10:00 | Kitware Robot | Status | todo => closed | ||
2016-08-12 10:00 | Kitware Robot | Fixed in Version | 5.0.1 => | ||
2016-08-12 10:00 | Kitware Robot | Resolution | fixed => moved |
Notes | |||||
