MantisBT - ParaView | |||||
View Issue Details | |||||
0016762 | ParaView | (No Category) | public | 2016-06-29 13:55 | 2016-08-12 10:00 |
Reporter | Alan Scott | ||||
Product Version | 5.0.1 | ||||
Project | Sandia | ||||
Topic Name | |||||
Summary | 0016762: Multiple selections don't work correctly in parallel | ||||
Description | Multiple selections don't work correctly in parallel. I suspect that this is the tip of an iceberg. I have seen single point selections also be weird - but this finally allows us to replicate it. Utkarsh took a few tries, but was able to replicate this. * 8 remote pvservers, Linux, 5.0.1. (I don't know if it replicates the same with fewer pvservers.) * Open g1s1. Ask Utkarsh or me for this dataset. * Run ProcessIdScalars, Apply. Not necessary, but helps me describe where to select. * Go to last timestep. Back one timestep. * -Z * Select points on. * Not necessary, but you may want surface with edges. * Now, you want to rubber band select the lower tip of the medium blue material (white in vtkBlockColors). You want to rubber band select about 1/2" by 1/2", including a bit of the orange, the beige, and the medium blue. (You may need to cycle through this a few times.) * Outline. <<Bug>> Notice that many points are selected that are inside the dataset. I think they are on processor boundaries, but cannot tell. This is a bug. | ||||
Steps To Reproduce | |||||
Relationships | |||||
Attached Files | |||||
Issue History | |||||
2016-06-29 13:55 | Alan Scott | New Issue | |||
2016-06-29 13:55 | Alan Scott | Assigned To | => Alan Scott | ||
2016-06-29 15:15 | Alan Scott | Assigned To | Alan Scott => | ||
2016-08-12 10:00 | Kitware Robot | Note Added: 0039079 | |||
2016-08-12 10:00 | Kitware Robot | Status | backlog => closed | ||
2016-08-12 10:00 | Kitware Robot | Resolution | open => moved | ||
2016-08-12 10:00 | Kitware Robot | Assigned To | => Kitware Robot |
Notes | |||||
