MantisBT - ParaView | |||||
View Issue Details | |||||
0002149 | ParaView | (No Category) | public | 2005-08-12 16:20 | 2009-12-09 22:04 |
Reporter | Ryan | ||||
Assigned To | Berk Geveci | ||||
Priority | normal | Severity | major | Reproducibility | always |
Status | closed | Resolution | not fixable | ||
Product Version | |||||
Project | |||||
Topic Name | |||||
Type | |||||
Summary | 0002149: LA: Calculator fails to handle identical attribute names | ||||
Description | When the "Append Attributes" filter is applied to two datasets which have attributes with the same name, the calculator only shows one instance of the attribute name. This means you cant distinguish between one dataset and another when the attribute names are the same. Perhaps there should be a prefix with the datasets name in the calculator scalar and vector menus? | ||||
Steps To Reproduce | |||||
Relationships | |||||
Attached Files | |||||
Issue History | |||||
2009-12-09 14:51 | Berk Geveci | Project | @3@ => ParaView | ||
2009-12-09 22:04 | Berk Geveci | Note Added: 0018785 | |||
2009-12-09 22:04 | Berk Geveci | Status | tabled => closed | ||
2009-12-09 22:04 | Berk Geveci | Resolution | open => not fixable | ||
Notes | |||||
