(0005846)
Ken Moreland
2006-11-30 22:53
This is the same behavior as ParaView 2. What is happening is that in the first time step, all the values are 0, so the range is basically 0 also. When you move to the last time step, the range stays the same. This is by design as it can be misleading to have the scalar range change (and hence the color mapping) change every time step. You can replicate the same behavior by resetting the range of the color map rather than swap variables.
We can still argue about whether this is a bug or not, but it is certainly not clear what the correct behavior is. |
