MantisBT - ParaView | |||||
View Issue Details | |||||
0003054 | ParaView | (No Category) | public | 2006-03-29 16:13 | 2006-12-19 14:09 |
Reporter | David Rogers | ||||
Priority | urgent | Severity | feature | Reproducibility | always |
Status | closed | Resolution | fixed | ||
Product Version | |||||
Project | |||||
Topic Name | |||||
Type | |||||
Summary | 0003054: Add capabilites to xml defining proxy properties | ||||
Description | 1. Allow xml to define order in which properties are retrieved (currently, this is alphabetical) 2. Add 'Description' string, describing the property. This can be used, for example, by the UI for 'help'. 3. Add 'Basic,Advanced' attribute of a property. Default value of a property without this attribute is 'Basic' 4. Add 'Label' attribute of a property. This is a string that can be used, for example, in a UI to give the user a better, more understandable name for the property. | ||||
Steps To Reproduce | |||||
Relationships | |||||
Attached Files | |||||
Issue History | |||||
Notes | |||||
