MantisBT - ParaView | |||||
View Issue Details | |||||
0003724 | ParaView | (No Category) | public | 2006-09-06 19:24 | 2008-04-07 17:36 |
Reporter | Alan Scott | ||||
Assigned To | Alan Scott | ||||
Priority | low | Severity | minor | Reproducibility | unable to reproduce |
Status | closed | Resolution | unable to reproduce | ||
Product Version | |||||
Project | |||||
Topic Name | |||||
Type | |||||
Summary | 0003724: SNL: Composite/Geometry bug | ||||
Description | There appears to be the following strange bug. 1. Set Composite slider to 10 MB 2. Set Bounding Box Threshold slider to something small 3. Open data 4. Adjust bounding box size to 500M cells (the data set stays as a bounding box) 5. Change display type on the reader to surface At this point, ParaView appears to be sending all of the geometry down to the client even though the data is larger than 10 MB. The client hung for about 10 minutes during this period. The solution was prior to opening data, make sure the composite slider is at 0MB and the Bounding Box Threshold slider was at 500M cells. | ||||
Steps To Reproduce | |||||
Relationships | |||||
Attached Files | |||||
Issue History | |||||
2007-08-03 17:35 | Berk Geveci | Project | @5@ => ParaView | ||
2007-08-03 17:37 | Berk Geveci | Note Deleted: 0008147 | |||
2007-08-03 17:38 | Berk Geveci | Assigned To | Bob O'Bara => Berk Geveci | ||
2007-08-03 17:38 | Berk Geveci | Priority | high => low | ||
2007-08-03 17:38 | Berk Geveci | Reproducibility | always => unable to reproduce | ||
2007-08-03 17:38 | Berk Geveci | Resolution | duplicate => unable to reproduce | ||
2007-08-03 17:57 | Berk Geveci | Summary | Goodsite => SNL: Composite/Geometry bug | ||
2008-04-07 11:42 | Berk Geveci | Note Added: 0011086 | |||
2008-04-07 11:42 | Berk Geveci | Assigned To | Berk Geveci => Alan Scott | ||
2008-04-07 17:36 | Alan Scott | Status | tabled => closed | ||
2008-04-07 17:36 | Alan Scott | Note Added: 0011127 | |||
Notes | |||||
