(0004914)
Kevin Hobbs
2006-09-14 11:41
The render window also freezes when I threshold the wavelet.
I am able to save the output of both the clip and threshold to a '.vtu' file and in both cases the render window freezes as soon as I load the saved data.
Could this be an unstructured grid problem? |
(0004915)
Kevin Hobbs
2006-09-14 13:15
I changed to debug mode and did "make clean && make" and I get :
terminate called after throwing an instance of 'std::bad_alloc'
what(): St9bad_alloc |
(0004916)
Kevin Hobbs
2006-09-14 13:40
I produced a backtrace frome the 1.1 GB core that paraview produced and atached it in bt.txt. |
(0004917)
Kevin Hobbs
2006-09-14 14:32
#8 0x00002aaaaf3c899b in vtkOpenGLTexture::Load (this=0x2a43e80, ren=0xa6b1a0) at /home/kevin/kitware/ParaView/VTK/Rendering/vtkOpenGLTexture.cxx:202
This line is :
resultData = new unsigned char [rowLength*ysize];
ddd tells me that rowLength and ysize are monstrous negative numbers
when I put a breakpoint there. xsize is also a huge negative number.
size[0] = 256, size[1] = 1, and size[2] = 1 do these make sense? |
(0004925)
Kevin Hobbs
2006-09-15 14:14
I did a clean build today starting with "rm -r *" in the build directory. The behavior is the same as yesterday except now ParaView does not immediately exit when I update the clip, and it produces the message below when I click on the render viewport.
ErrorMessage
# Error or warning: There was a VTK Error in file: /home/kevin/kitware/ParaView/GUI/Widgets/vtkKWApplication.cxx (999)
vtkPVApplication (0x7024c0): TclTk error: Uncaught exception: St9bad_alloc
while executing
"vtkTemp2 MouseAction 2 1 274 87 0 0"
(command bound to event)
ErrorMessage end |
(0004932)
Kevin Hobbs
2006-09-15 16:44
I can now relate this bug to one of the tests that fail on gargon.hooperlab, that is :
http://paraview.org/Testing/Sites/gargon.hooperlab/Linux-c++/20060915-1537-Experimental/Results/__GUI_Testing_Tcl_CalcInput-batch-ParaView.html [^]
I copied the file "/home/kevin/kitware/ParaView/GUI/Testing/Tcl/CalcInput.pvs" and commented out the lines that source things and close the window :
diff /home/kevin/kitware/ParaView/GUI/Testing/Tcl/CalcInput.pvs CalcInput.pvs
4,5c4,5
< source [file join [file dirname [info script]] CommandLineOptions.tcl]
< ParseCommandLine $pv(vtkTemp43) $argv $argc
> #source [file join [file dirname [info script]] CommandLineOptions.tcl]
> #ParseCommandLine $pv(vtkTemp43) $argv $argc
49,50c49,50
< source [file join [file dirname [info script]] Compare.tcl]
< Compare $Application $argv $argc
> #source [file join [file dirname [info script]] Compare.tcl]
> #Compare $Application $argv $argc
52c52
< $Application Exit
> #$Application Exit
When I run "paraview CalcInput.pvs" ParaView is left in the same frozen render viewport state I've described before. I can see only the sphere. If I click on the render viewport I get the message below and ParaView exits.
Aborted |
(0004960)
Kevin Hobbs
2006-09-18 11:43
It looks to me like FindPowerOfTwo is returning crazy numbers. It proceeds through the for loop and sets size to 265. Then after glGetIntegerv, maxDimGL is a huge negative number so of course size is set to this huge negative number. I don't have debug symbols for glGetIntegerv, so I have no idea what it's doing. |
(0004969)
Kevin Hobbs
2006-09-19 09:37
I noticed that the of the ClipCut tests run on gargon batch failed while the ClientServer and RenderServer tests passed. I tried my little test where I bring up the wavelet source and clip it in paraview with offscreen rendering on and it works. Without offscreen rendering the viewport hangs and mesa complains about the invalid context.
I just tried some things on our Beowulf cluster as pvserver and my workstation as the pvclient. I tried opening up the wavelet source ( worked ), contouring ( worked ), color by process id ( worked ), but as soon as I clip anything the pvserver dies with a segfault.
The pvserver complained as below but it was run with --use-offscreen-rendering. The server was built with mesa as the only GL.
Connected to client
Process id: 0 >> ERROR: In /home/khobbs/kitware/ParaView/VTK/Rendering/vtkXOpenG
LRenderWindow.cxx, line 482
vtkXOpenGLRenderWindow (0x936aba0): bad X server connection.
LRenderWindow.cxx, line 309
mpiexec: Warning: task 0 died with signal 11 (Segmentation fault). |
(0004975)
Kevin Hobbs
2006-09-19 15:16
(0005059)
Kevin Hobbs
2006-09-28 08:09
