(0006032)
Ken Moreland
2006-12-20 16:38
You can now set the center of rotation to the center of the geometry. However, the ability to pick or specify coordinates of the center of rotation is still missing. |
(0006468)
Utkarsh Ayachit
2007-02-20 09:10
If I remember correctly, we decided to defer the picking of center of rotation. |
(0006520)
Ken Moreland
2007-02-21 17:12
That sounds about right to me, too. I'll lower the priority of this bug so that it is readdressed for PV 3.2. |
(0008486)
Berk Geveci
2007-08-16 14:35
We should support picking center of rotation in 3.2. |
(0008879)
Dave DeMarle
2007-09-07 09:42
Almost fixed. Pick in parallel gets wrong Z value, actually it does in 2.6 as well. But other than that this change fixes it.
/cvsroot/ParaView3/ParaView3/Qt/Components/Resources/Icons/pqEnterCenter24.png,v <-- pqEnterCenter24.png
initial revision: 1.1
/cvsroot/ParaView3/ParaView3/Qt/Components/Resources/Icons/pqPickCenter24.png,v <-- pqPickCenter24.png
/cvsroot/ParaView3/ParaView3/Qt/Core/pqPickHelper.h,v <-- pqPickHelper.h
/cvsroot/ParaView3/ParaView3/Qt/Core/pqPickHelper.cxx,v <-- pqPickHelper.cxx
/cvsroot/ParaView3/ParaView3/Qt/Core/CMakeLists.txt,v <-- CMakeLists.txt
new revision: 1.87; previous revision: 1.86
/cvsroot/ParaView3/ParaView3/Applications/Client/MainWindow.cxx,v <-- MainWindow.cxx
new revision: 1.128; previous revision: 1.127
/cvsroot/ParaView3/ParaView3/Applications/Client/MainWindow.ui,v <-- MainWindow.ui
new revision: 1.88; previous revision: 1.87
/cvsroot/ParaView3/ParaView3/Qt/Components/pqMainWindowCore.cxx,v <-- pqMainWindowCore.cxx
new revision: 1.214; previous revision: 1.213
/cvsroot/ParaView3/ParaView3/Qt/Components/pqMainWindowCore.h,v <-- pqMainWindowCore.h
new revision: 1.76; previous revision: 1.75
/cvsroot/ParaView3/ParaView3/Qt/Components/Resources/pqComponents.qrc,v <-- pqComponents.qrc
new revision: 1.27; previous revision: 1.26 |
(0009485)
Utkarsh Ayachit
2007-10-15 16:26
ENH: Added API to get z buffer at a point.
/cvsroot/ParaView3/ParaView3/VTK/Rendering/vtkRenderWindow.h,v <-- vtkRenderWindow.h
new revision: 1.155; previous revision: 1.154 |
(0009490)
Utkarsh Ayachit
2007-10-16 10:11
ZBuffer value can now be queried in client-server mode with/wihtout IceT. In client-server w/o parallel, vtkPVDesktopDeliveryServer can capure the Z buffer data which can be queried using GetZBufferValue. When using IceT, the same is true with vtkIceTRenderManager which works in collaboration with vtkIceTRender to get Z buffer from IceT.
new revision: 1.235; previous revision: 1.234
new revision: 1.81; previous revision: 1.80
new revision: 1.2; previous revision: 1.1
new revision: 1.132; previous revision: 1.131
new revision: 1.94; previous revision: 1.93
/cvsroot/ParaView3/ParaView3/Servers/Filters/vtkIceTRenderManager.cxx,v <-- vtkIceTRenderManager.cxx
new revision: 1.42; previous revision: 1.41
/cvsroot/ParaView3/ParaView3/Servers/Filters/vtkIceTRenderManager.h,v <-- vtkIceTRenderManager.h
new revision: 1.22; previous revision: 1.21
/cvsroot/ParaView3/ParaView3/Servers/Filters/vtkIceTRenderer.cxx,v <-- vtkIceTRenderer.cxx
new revision: 1.26; previous revision: 1.25
/cvsroot/ParaView3/ParaView3/Servers/Filters/vtkIceTRenderer.h,v <-- vtkIceTRenderer.h
new revision: 1.10; previous revision: 1.9
/cvsroot/ParaView3/ParaView3/Servers/Filters/vtkPVDesktopDeliveryServer.cxx,v <-- vtkPVDesktopDeliveryServer.cxx
/cvsroot/ParaView3/ParaView3/Servers/Filters/vtkPVDesktopDeliveryServer.h,v <-- vtkPVDesktopDeliveryServer.h
/cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMClientServerRenderViewProxy.cxx,v <-- vtkSMClientServerRenderViewProxy.cxx
new revision: 1.9; previous revision: 1.8
/cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMClientServerRenderViewProxy.h,v <-- vtkSMClientServerRenderViewProxy.h
new revision: 1.8; previous revision: 1.7
/cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMIceTDesktopRenderViewProxy.cxx,v <-- vtkSMIceTDesktopRenderViewProxy.cxx
new revision: 1.14; previous revision: 1.13
/cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMIceTDesktopRenderViewProxy.h,v <-- vtkSMIceTDesktopRenderViewProxy.h
/cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMRenderViewProxy.cxx,v <-- vtkSMRenderViewProxy.cxx
new revision: 1.51; previous revision: 1.50 |
(0009503)
Alan Scott
2007-10-17 17:09
Blackrose is down, verified in XP local mode. |
