(0007772)
Berk Geveci
2007-06-02 08:57
The documentation is there now we need to make the help come up with the right page. |
(0011379)
Clinton Stimpson
2008-04-15 18:44
Fixed. There's a new help button in the object inspector. |
(0011423)
Alan Scott
2008-04-17 19:53
This only works if the user runs ParaView from the ParaView3 directory - not the ParaView3/bin directory. If you step into the bin directory and run paraview.exe, or run from somewhere else (for instance ../ParaView3/bin/paraview.exe), this fails.
An example failure output is as follows:
The page could not be found
'file:///c:/alan/paraviewnightlytrunk/scripts/documentation/clip.html' [^]
Note that my file structure is as follows:
scripts (where I have a script that starts ParaView client/server)
bld/ParaView3, where the bin directory actually is.
src/ParaView3. |
(0011433)
Clinton Stimpson
2008-04-18 13:00
Good find. Fixed.
/cvsroot/ParaView3/ParaView3/Applications/Client/MainWindow.cxx,v <-- MainWindow.cxx
new revision: 1.142; previous revision: 1.141 |
(0011471)
Alan Scott
2008-04-21 20:45
(0011539)
Clinton Stimpson
2008-04-24 17:31
I'm not able to reproduce the error. I don't see how it can even end up with c:/windows/system32/documentation, unless you have a stray pqClient.adp in the system32 folder, and your paraview.exe was some place relative to system32. |
(0011540)
Alan Scott
2008-04-24 17:54
It works now. I have no idea why it was giving troubles.
Closed, tested client/server. |
