(0006215)
Utkarsh Ayachit
2007-01-17 11:24
Adding Cache check box.
/cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMAnimationCueProxy.cxx,v <-- vtkSMAnimationCueProxy.cxx
new revision: 1.16; previous revision: 1.15
/cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMAnimationSceneProxy.cxx,v <-- vtkSMAnimationSceneProxy.cxx
new revision: 1.35; previous revision: 1.34
/cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMProxyProperty.cxx,v <-- vtkSMProxyProperty.cxx
new revision: 1.40; previous revision: 1.39
/cvsroot/ParaView3/ParaView3/Qt/Components/pqAnimationPanel.cxx,v <-- pqAnimationPanel.cxx
new revision: 1.5; previous revision: 1.4
/cvsroot/ParaView3/ParaView3/Qt/Components/Resources/UI/pqAnimationPanel.ui,v <-- pqAnimationPanel.ui
new revision: 1.4; previous revision: 1.3
(0006254)
Utkarsh Ayachit
2007-01-24 15:24
Added mechanism to keep track of memory used by update suppressor caches. Every render module has a cache limit, when the cache size goes beyond that limit, the cache is not longer maintained for any new frames generated. However all previous generated cache is kept and used for playing.
Limit can be chaged from View|Settings dialog.
/cvsroot/ParaView3/ParaView3/Servers/Common/CMakeLists.txt,v <-- CMakeLists.txt
new revision: 1.52; previous revision: 1.51
/cvsroot/ParaView3/ParaView3/Servers/Common/vtkCacheSizeKeeper.cxx,v <-- vtkCacheSizeKeeper.cxxinitial revision: 1.1
/cvsroot/ParaView3/ParaView3/Servers/Common/vtkCacheSizeKeeper.h,v <-- vtkCacheSizeKeeper.h
/cvsroot/ParaView3/ParaView3/Servers/Common/vtkPVCacheSizeInformation.cxx,v <-- vtkPVCacheSizeInformation.cxx
/cvsroot/ParaView3/ParaView3/Servers/Common/vtkPVCacheSizeInformation.h,v <-- vtkPVCacheSizeInformation.h
/cvsroot/ParaView3/ParaView3/Servers/Common/vtkProcessModule.cxx,v <-- vtkProcessModule.cxx
new revision: 1.66; previous revision: 1.65
/cvsroot/ParaView3/ParaView3/Servers/Common/vtkProcessModule.h,v <-- vtkProcessModule.h
new revision: 1.53; previous revision: 1.52
/cvsroot/ParaView3/ParaView3/Servers/Filters/vtkPVUpdateSuppressor.cxx,v <-- vtkPVUpdateSuppressor.cxx
new revision: 1.42; previous revision: 1.41
/cvsroot/ParaView3/ParaView3/Servers/Filters/vtkPVUpdateSuppressor.h,v <-- vtkPVUpdateSuppressor.h
new revision: 1.19; previous revision: 1.18
/cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMRenderModuleProxy.cxx,v <-- vtkSMRenderModuleProxy.cxx
new revision: 1.61; previous revision: 1.60
/cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMRenderModuleProxy.h,v <-- vtkSMRenderModuleProxy.h
new revision: 1.28; previous revision: 1.27
/cvsroot/ParaView3/ParaView3/Servers/ServerManager/Resources/filters.xml,v <-- filters.xml
new revision: 1.167; previous revision: 1.166
/cvsroot/ParaView3/ParaView3/Servers/ServerManager/Resources/rendering.xml,v <-- rendering.xml
new revision: 1.123; previous revision: 1.122
/cvsroot/ParaView3/ParaView3/Qt/Components/pq3DViewPropertiesWidget.cxx,v <-- pq3DViewPropertiesWidget.cxx
new revision: 1.14; previous revision: 1.13
/cvsroot/ParaView3/ParaView3/Qt/Components/Resources/UI/pq3DViewPropertiesWidget.ui,v <-- pq3DViewPropertiesWidget.ui
new revision: 1.11; previous revision: 1.10
/cvsroot/ParaView3/ParaView3/Qt/Core/pqRenderViewModule.cxx,v <-- pqRenderViewModule.cxx
