(0006218)
user521
2007-01-17 13:41
I added a facility for calculating min, max and sum of attribute values in vtkMinMax.cxx and for returning the result to the client via a paraview.fetch(), a python function. To do the parallel aggregation vtkReductionFilter tells each node to execute vtkMinMax to produce a per node min/max/sum, and then gathers the results to the root node and executes vtkMinMax again to produce a global min/max/sum.
Question 1: Do we want to make these general gather and aggregate operations available in the GUI, or are they solely meant for scripted applications?
For min/max/sum we have to execute vtkMinMax on the per node results to get a global result. However the default gather operation for the paraview GUI is to simply concatenate all per node results. For this reason vtkMinMax is not available from the GUI.
Question 1: Min/max/sum of attribute values is a very simple type of aggregation - it simply discards all geometry and aggregates the data values. What type of geometric aggregation do we need and for what data types?
