MantisBT - ParaView | |||||
View Issue Details | |||||
0004371 | ParaView | (No Category) | public | 2007-01-25 19:49 | 2009-12-09 14:50 |
Reporter | Alan Scott | ||||
Assigned To | Amy Squillacote | ||||
Priority | high | Severity | major | Reproducibility | always |
Status | closed | Resolution | no change required | ||
Product Version | |||||
Project | |||||
Topic Name | |||||
Type | |||||
Summary | 0004371: SNL: GLYPH filter can't set scale factors correctly - 2.6 | ||||
Description | * The GLYPH filter has lost the ability to set the scale factors correctly. Here are details on how to replicate this bug. * Windows XP machine. * Debug build (probably not important) * Run ParaView 2.6, from this Monday or Tuesday (probably not important). * Open can.ex2 (We have numerous versions of can running around here. We believe that they are exactly the same. The extension has been changed to make sure ParaView uses the correct reader for multiple extensions.) * Node variables - All On. * Accept. * Play the animation. * Go to the start of the animation. (left button on the animation panel). * Glyph filter. * Change Orient/Scale, Vectors to ACCL. * Read Scale Factor - BAD. Here are details to hid the bug. * Run ParaView 2.6, from this Monday or Tuesday (probably not important). * Open can.ex2 (We have numerous versions of can running around here. We believe that they are exactly the same. The extension has been changed to make sure ParaView uses the correct reader.) * Node variables - All On. * Accept. * Play the animation. (* Go to the start of the animation. (left button on the animation panel).) - DON'T do this. * Glyph filter. * Change Orient/Scale, Vectors to ACCL. * Read Scale Factor - GOOD. | ||||
Steps To Reproduce | |||||
Relationships | |||||
Attached Files | |||||
Issue History | |||||
2009-12-09 14:50 | Berk Geveci | Project | @3@ => ParaView | ||
Notes | |||||
