(0006813)
Mark Richardson
2007-03-15 17:48
I believe this one is fixed. At least for my test case. If you still have this problem, reopen the bug and give me an example. |
(0006835)
Ken Moreland
2007-03-19 13:10
I still get the same behavior.
1. Create a Sphere source.
2. Add a filter to the Sphere source (e.g. clip).
3. Click on the Sphere source in the pipeline browser.
4. Look at the object inspector. The Delete button is active (it should be grayed out). When you click on it, you get the message "Cannot remove source with consumers." |
(0006837)
Mark Richardson
2007-03-19 13:30
Sorry, I thought you were talking about the delete item on the context menu. I'll get the button fixed right away. |
(0006841)
Mark Richardson
2007-03-19 14:36
The delete button on the object panel is only enabled when the object has no consumers. |
(0006844)
Clinton Stimpson
2007-03-19 17:01
Make a source and connect a filter to it.
hit the delete button on the filter panel, and it takes you back to the source's panel with the delete button still disabled. It should be enabled.
(0006847)
Mark Richardson
2007-03-19 18:20
The delete button enabled state now listens for pipeline connection changes as well as selection changes. |
