MantisBT - ParaView | |||||
View Issue Details | |||||
0004448 | ParaView | (No Category) | public | 2007-02-12 17:27 | 2008-04-07 16:48 |
Reporter | Ken Moreland | ||||
Assigned To | Ken Moreland | ||||
Priority | normal | Severity | feature | Reproducibility | always |
Status | closed | Resolution | fixed | ||
Product Version | |||||
Project | |||||
Topic Name | |||||
Type | |||||
Summary | 0004448: Time multiplexer filter | ||||
Description | We should have a filter that multiplexes over time. It will take multiple inputs, each with the same geometry defined over different regions of time. The time regions may overlap some. If this is the case, then the multiplexer should get the geometry from the input whos maximum time step is greater. This filter will finally make it possible to load in simulation results from multiple restarts without combining the results together. | ||||
Steps To Reproduce | |||||
Relationships | |||||
Attached Files | |||||
Issue History | |||||
2007-08-13 16:20 | Berk Geveci | Assigned To | Berk Geveci => Ken Moreland | ||
2007-08-13 16:21 | Berk Geveci | Priority | normal => high | ||
2007-08-23 17:10 | Berk Geveci | Category | => 3.2 | ||
2007-10-18 13:26 | Berk Geveci | Priority | high => normal | ||
2008-04-07 16:48 | Berk Geveci | Status | tabled => closed | ||
2008-04-07 16:48 | Berk Geveci | Note Added: 0011123 | |||
2008-04-07 16:48 | Berk Geveci | Resolution | open => fixed | ||
Notes | |||||
