(0011872)
Utkarsh Ayachit
2008-05-13 14:51
Make light kit default. Changed widget labels. Fixed tests to disable light kit and added a test with light kit enabled.
commitid: nviKJZ6f0bhjRP2t
/cvsroot/ParaView3/ParaView3/Qt/Core/pqRenderView.cxx,v <-- Qt/Core/pqRenderView.cxx
new revision: 1.35; previous revision: 1.34
/cvsroot/ParaView3/ParaView3/Servers/ServerManager/Resources/rendering.xml,v <-- Servers/ServerManager/Resources/rendering.xml
new revision: 1.287; previous revision: 1.286
/cvsroot/ParaView3/ParaView3/Applications/Client/Testing/Cxx/ManualConnectBuiltin.xml.in,v <-- Applications/Client/Testing/Cxx/ManualConnectBuiltin.xml.in
new revision: 1.3; previous revision: 1.2
/cvsroot/ParaView3/ParaView3/Applications/Client/Testing/Cxx/ManualConnectCRSDS.xml.in,v <-- Applications/Client/Testing/Cxx/ManualConnectCRSDS.xml.in
/cvsroot/ParaView3/ParaView3/Applications/Client/Testing/Cxx/ManualConnectCRSDSRR.xml.in,v <-- Applications/Client/Testing/Cxx/ManualConnectCRSDSRR.xml.in
new revision: 1.4; previous revision: 1.3
/cvsroot/ParaView3/ParaView3/Applications/Client/Testing/Cxx/ManualConnectCS.xml.in,v <-- Applications/Client/Testing/Cxx/ManualConnectCS.xml.in
new revision: 1.2; previous revision: 1.1
/cvsroot/ParaView3/ParaView3/Applications/Client/Testing/Cxx/ManualConnectCSRR.xml.in,v <-- Applications/Client/Testing/Cxx/ManualConnectCSRR.xml.in
/cvsroot/ParaView3/ParaView3/Applications/Client/Testing/XML/XdmfReadImageData.xml,v <-- Applications/Client/Testing/XML/XdmfReadImageData.xml
new revision: 1.3; previous revision: 1.2 |
(0011936)
Alan Scott
2008-05-14 19:35
Using this morning's trunk, when I go Edit/ View Settings/ Lights, and hit the Reset button, it defaults to "Default Light". Shouldn't this reset to Light Kit, as stated below? Also, it still shows "Light Kit Parameters" |
(0011990)
Utkarsh Ayachit
2008-05-19 09:41
Reset button resets lights correcly
new revision: 1.36; previous revision: 1.35
/cvsroot/ParaView3/ParaView3/Qt/Core/pqRenderView.h,v <-- Qt/Core/pqRenderView.h
new revision: 1.19; previous revision: 1.18 |
(0012057)
Alan Scott
2008-05-21 22:28
Shouldn't the reset light button actually reset the numbers to a default? I change the Key/ Warm entry box from 0.60 to 0.70, hit reset light, and nothing happens. Client/Server. |
(0012556)
Utkarsh Ayachit
2008-06-27 09:58
Reset Light resets light parameters. It was resetting only the changed property values.
/cvsroot/ParaView3/ParaView3/Qt/Components/pqRenderViewOptions.cxx,v <-- Qt/Components/pqRenderViewOptions.cxx
new revision: 1.6; previous revision: 1.5 |
(0012590)
Alan Scott
2008-06-30 19:57
