(0007687)
user521
2007-05-18 10:57
I checked in the code yesterday. The new filter is called probe location over time.
(0008481)
Ken Moreland
2007-08-15 18:30
I ran into the following issues when trying this feature. When the plot showed up, it had a plot of vtkEAOTValidity, which is obviously some internal array that should not be displayed to the user. When running in client/server mode with a parallel server, an array called Cell's Point Ids was also added (and should not have been). Also, when running on the server (on the can.ex2 data set) I get a lot of the following error:
ERROR: In C:\kmorel\src\ParaView3\VTK\Common\vtkDataArray.cxx, line 457
vtkIdTypeArray (0BF48AA0): The number of components do not match the number requested: 8 != 1
This is probably due to the fact that the exodus reader is loading everything into node 0. If I run the data through the D3 filter and then the Probe Location Over Time, I don't get these errors. |
(0009028)
Utkarsh Ayachit
2007-09-17 13:32
Changed vtkEAOTValidity array name to vtkValidPointMask to
be consistent with probe. Removed "Cell's Point Ids" from the list of available
arrays.
/cvsroot/ParaView3/ParaView3/VTK/Parallel/vtkPExtractArraysOverTime.cxx,v <-- vtkPExtractArraysOverTime.cxx
/cvsroot/ParaView3/ParaView3/VTK/Graphics/vtkExtractTemporalFieldData.cxx,v <-- vtkExtractTemporalFieldData.cxx
new revision: 1.3; previous revision: 1.2
/cvsroot/ParaView3/ParaView3/VTK/Graphics/vtkExtractArraysOverTime.cxx,v <-- vtkExtractArraysOverTime.cxx
new revision: 1.15; previous revision: 1.14
/cvsroot/ParaView3/ParaView3/Qt/Core/pqLineChartRepresentation.cxx,v <-- pqLineChartRepresentation.cxx
new revision: 1.14; previous revision: 1.13 |
(0009032)
Utkarsh Ayachit
2007-09-17 16:42
I could not reproduce the error anymore. Can you verify if it got fixed somehow? |
(0009037)
Ken Moreland
2007-09-17 17:18
I now get the following errors with can.ex2 on black rose with 8 or more processes.
ERROR: In C:\kmorel\src\ParaView3\VTK\Filtering\vtkStreamingDemandDrivenPipeline.cxx, line 698
vtkCompositeDataPipeline (0BEB3B30): The update extent specified in the information for output port 0 on algorithm vtkPolyLineToRectilinearGridFilter(0BEB2580) is 0 2147483647 0 2147483647 0 2147483647, which is outside the whole extent 0 -1 0 -1 0 -1.
vtkCompositeDataPipeline (0BEB3B30): The update extent specified in the information for output port 0 on algorithm vtkPolyLineToRectilinearGridFilter(0BEB2580) is 0 2147483647 0 2147483647 0 2147483647, which is outside the whole extent 0 43 0 0 0 0.
I have been placing the probe at (0,5,-14). |
(0009112)
Utkarsh Ayachit
2007-09-19 09:22
UpdateDependentDomains was getting called before input to
the PolyLineToRectilinearGrid filter was set.
/cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMXYPlotRepresentationProxy.cxx,v <-- vtkSMXYPlotRepresentationProxy.cxx
new revision: 1.3; previous revision: 1.2 |
(0009293)
Alan Scott
2007-09-25 19:56
