(0007526)
Ken Moreland
2007-04-30 13:46
I do not think this problem has anything to do with D3, with multiple files, or with running in parallel. I am assuming that Dave was looking at the BlockId of the g1s1 data set, however, I can replicate the same problem with disk_out_ref on one process.
To replicate, do the following:
1. Load disk_out_ref. Notice that the range of BlockId is [1,1].
2. Run through Cell To Point. BlockId range is now [0,1].
I'm guessing there is a problem with cell to point when you have integer data. I base this mostly on the fact that I cannot replicate the problem with data generated by the calculator filter, which outputs double data. |
