(0009326)
Clinton Stimpson
2007-09-28 12:57
Can I get some feedback on this?
I wasn't sure whether to snap the interaction in "sequence" mode and "snap to timesteps" mode.
Also, one can move the current time bar.
/cvsroot/ParaView3/ParaView3/Qt/Components/pqAnimationViewWidget.cxx,v <-- pqAnimationViewWidget.cxx
new revision: 1.29; previous revision: 1.28
/cvsroot/ParaView3/ParaView3/Qt/Components/pqAnimationViewWidget.h,v <-- pqAnimationViewWidget.h
new revision: 1.11; previous revision: 1.10
/cvsroot/ParaView3/ParaView3/Qt/Widgets/pqAnimationModel.cxx,v <-- pqAnimationModel.cxx
new revision: 1.24; previous revision: 1.23
/cvsroot/ParaView3/ParaView3/Qt/Widgets/pqAnimationModel.h,v <-- pqAnimationModel.h
new revision: 1.8; previous revision: 1.7
(0009334)
Ken Moreland
2007-09-28 13:24
Very cool.
Yes, the snapping should occur in sequence and snap to timesteps modes. In either mode, the keyframes should snap to the points of time the animation will visit. Also, in all modes, snapping to the current time and to keyframe times of other tracks should also work.
I also found a bug. You can only drag the tracks properly if the start time is 0 and the end time is 1. |
(0009336)
Clinton Stimpson
2007-09-28 14:53
Ok, it snaps now. And interaction with a non-(0,1) range is fixed.
new revision: 1.30; previous revision: 1.29
/cvsroot/ParaView3/ParaView3/Qt/Components/pqComparativeTracksWidget.cxx,v <-- pqComparativeTracksWidget.cxx
/cvsroot/ParaView3/ParaView3/Qt/Widgets/pqAnimationKeyFrame.cxx,v <-- pqAnimationKeyFrame.cxx
new revision: 1.9; previous revision: 1.8
/cvsroot/ParaView3/ParaView3/Qt/Widgets/pqAnimationKeyFrame.h,v <-- pqAnimationKeyFrame.h
new revision: 1.6; previous revision: 1.5
new revision: 1.25; previous revision: 1.24
/cvsroot/ParaView3/ParaView3/Qt/Widgets/Testing/Animation.cxx,v <-- Animation.cxx
new revision: 1.3; previous revision: 1.2
(0009337)
Clinton Stimpson
2007-09-28 15:46
Snap to other keyframe times. Also prevent going past other keyframe times on the same track.
new revision: 1.26; previous revision: 1.25
new revision: 1.10; previous revision: 1.9 |
(0009338)
Clinton Stimpson
2007-09-28 17:15
Now in 3.2.
new revision: 1.28.4.1; previous revision: 1.28
new revision: 1.10.4.1; previous revision: 1.10
new revision: 1.8.4.1; previous revision: 1.8
new revision: 1.5.4.1; previous revision: 1.5
new revision: 1.23.4.1; previous revision: 1.23
new revision: 1.7.4.1; previous revision: 1.7
new revision: 1.2.4.1; previous revision: 1.2 |
(0009359)
Alan Scott
2007-10-01 20:39
Seemed to work for me. (Not totally sure if I actually understood and tested the fix...) Tested in 3.2 and cvs head. Local ParaView. |
