(0008494)
Alan Scott
2007-08-16 19:00
In ParaView 2.6, you do this with the icon that looks like a ruler. It is a line source. You place the ends of the line on a surface by hitting the 'p' key. The length is displayed right below the x,y, and z of point 1 and point 2 (on the Parameters tab).
PV 3.0 has a line source, but 1) you cannot place the ends easily on the top of a surface, and 2) it does not display the length of the line. |
(0010548)
Alan Scott
2008-02-18 15:18
I am changing this to High priority. We have had multiple requests that we have some type of ruler function. We need to at least implement either this feature, or 5422. |
(0011947)
Utkarsh Ayachit
2008-05-15 13:57
Change line source to show length information somewhere. |
(0011974)
Utkarsh Ayachit
2008-05-16 15:56
A new "Ruler" source has been added. |
(0012060)
Alan Scott
2008-05-21 22:50
I'm pretty sure this is messing up the cube axis. Thus, asking for feedback on this bug.
Please run exactly as follows:
* Client/server - 6 servers. XP client.
* Open disk_out_ref.exo. Apply.
* Sources/ Ruler. (Don't hit apply)
* On bottom of cylinder, hit a 'p'.
* On top of cylinder, hit a 'p'.
(Note, it would sure be nice to document somehow that you could hit a p here.)
(Note, it would sure be nice to auto-accept here.)
* Apply.
* Display tab/ Show cube axes. The axes are located inside of the cylinder. |
(0012061)
Alan Scott
2008-05-21 22:54
Ah-hah. Lots of the junk above doesn't have to be done - the cube axes for the ruler is always weird. Turns out that it is putting the cube axes around the ruler itself. Does this make sense - should we just leave it, or should we turn off the Show Cube Axes for the ruler (and does that make sense)? |
(0012068)
Utkarsh Ayachit
2008-05-22 07:42
Berk was suggesting we don't create any representation for the ruler. In otherwords, the display tab will never be enabled for the ruler, hence one will never see the cube-axes. Does that work?
I am guessing, however, the cube-axes has issues dealing with 1D data. So that is a bug we'd surely want to fix at some point. |
(0012167)
Utkarsh Ayachit
2008-05-30 14:55
We can no longer apply cube-axes to the ruler. |
(0012192)
Alan Scott
2008-06-02 18:58
Very nice.
Now, when we turn on the ruler, and hit Apply (the button goes green), a seperate window opens up - with only the ruler in it.
XP client/ 6 pvservers
Open can.exo, apply.
Sources/ Ruler/ apply. |
(0012193)
Alan Scott
2008-06-02 18:59
Oh yes - when you close the separate window, PV crashes. |
(0012271)
Utkarsh Ayachit
2008-06-06 09:42
* vtkLineRepresentation was not passing the renderer to the internal
representations, consequently, when the view was destroyed the internal
representations had a dangling pointer which led to segfaults.
* pqDisplayPolicy was create a new render view even when the render view could
not show the current source. This was resulting the a new 3D view being
created when a ruler source was created. Fixed that.
/cvsroot/ParaView3/ParaView3/Qt/Core/pqDisplayPolicy.cxx,v <-- Qt/Core/pqDisplayPolicy.cxx
new revision: 1.38; previous revision: 1.37
/cvsroot/ParaView3/ParaView3/VTK/Widgets/vtkLineRepresentation.cxx,v <-- VTK/Widgets/vtkLineRepresentation.cxx
new revision: 1.11; previous revision: 1.10
/cvsroot/ParaView3/ParaView3/VTK/Widgets/vtkLineRepresentation.h,v <-- VTK/Widgets/vtkLineRepresentation.h
new revision: 1.6; previous revision: 1.5 |
(0012296)
Alan Scott
2008-06-09 20:51
Great new feature.
Tested local client. Blackrose is down. |
