MantisBT - ParaView |
View Issue Details |
0005583 | ParaView | (No Category) | public | 2007-08-27 17:52 | 2007-09-11 15:21 |
Reporter | Ken Moreland | |
Assigned To | Utkarsh Ayachit | |
Priority | high | Severity | minor | Reproducibility | always |
Status | closed | Resolution | fixed | |
Product Version | | |
Target Version | | Fixed in Version | | |
Project | |
Topic Name | |
Type | |
Summary | 0005583: Interface seams are visible |
Description | At the seams of the data where two polygons meet at a large angle, you can sometimes see a "seam" between the two that is one pixel wide. For example, in the attached image is a simply cylinder source where you can see a white line in the back of the cylinder as if the bottom cap is a little wider than the body. |
Steps To Reproduce | |
Additional Information | The artifact happened very recently (within the last week). I wonder if it is related to the completion of bug 0004626. The seam remains 1 pixel regardless of how close or far you zoom. Some adjustment to the Z buffer might cause this effect. |
Tags | No tags attached. |
Relationships | related to | 0005667 | closed | Utkarsh Ayachit | Edges not visible on surface parallel to view plane |
Attached Files | Seam.png (64,850) 2007-08-27 17:52 https://www.vtk.org/Bug/file/6126/Seam.png
2007-08-27 17:52 | Ken Moreland | New Issue | |
2007-08-27 17:52 | Ken Moreland | File Added: Seam.png | |
2007-09-04 13:54 | Berk Geveci | Status | backlog => tabled |
2007-09-04 13:54 | Berk Geveci | Assigned To | => Utkarsh Ayachit |
2007-09-04 14:46 | Utkarsh Ayachit | Status | tabled => @80@ |
2007-09-04 14:46 | Utkarsh Ayachit | Resolution | open => fixed |
2007-09-04 14:46 | Utkarsh Ayachit | Note Added: 0008823 | |
2007-09-07 16:30 | Ken Moreland | Relationship added | related to 0005667 |
2007-09-11 15:21 | Alan Scott | Status | @80@ => closed |
