(0009415)
Ken Moreland
2007-10-11 13:10
This does not sound important enough to try to stuff into 3.2. I will downgrade the priority so that we can address it in 3.4. |
(0009708)
David Karelitz
2007-11-19 18:29
This also happens when loading state |
(0009754)
David Karelitz
2007-11-26 12:06
This appears to be related to the range domain applied to the FontSize property. When a max value is added, the text size appears correctly, but it is still not possible to change the text size. In addition, the following warning is generated (with and without a max value on the FontSize domain):
ERROR: In /home/projects/ParaView3-Trunk/ParaView3/VTK/Widgets/vtkAbstractWidget.cxx, line 118
vtkTextWidget (0x1434040): The interactor must be set prior to enabling the widget
The widget also cannot be moved interactively without turning off and back on the interactive checkbox. |
(0012072)
Alan Scott
2008-05-22 20:21
Tested client/server.
I tested lookmarks using can.exo, and save/load state using can.exo. |
