(0010056)
David Karelitz
2008-01-03 10:20
This happens with Exodus data as well.
When saving an animation using the GUI or through pvbatch, 3D geometry is not always from the correct timestep. If I open can.exo (which I believe Kitware has), add a time annotator, and save the animation, I get a the correct number of frames (one per timestep). The timestamp on each frame is correct, but the geometry is not correct. It is often duplicated from the previous frame. Out of 43 frames, there are only 33 different geometries.
If I load the state into the GUI, I see the same timestep discrepancies that I saw in the animation images. If I then open can.exo (with the version from the state file still there), the timesteps are still wrong. If I delete everything and open can.exo, the timesteps are correct. |
(0010057)
David Karelitz
2008-01-03 15:16
This turned out to be a problem due to the precision of the time values saved in pvsm files versus the precision used in the readers. It was fixed for Exodus and CTH by modifying the reader to snap to the nearest timestep versus the first timestep larger than the requested value. |
(0010271)
Alan Scott
2008-01-23 17:00
Tested client/server - using can.exo |
(0010294)
Alan Scott
2008-01-24 16:53
As per Dave, there are cases with some data and some clusters that this bug still occurs. Not to be closed until Dave says it is OK. |
(0010305)
David Karelitz
2008-01-28 10:32
Misunderstanding between myself and Alan as to which bug should remain open |
