(0015212)
Ken Moreland
2009-02-19 10:22
The Scalars and Vectors combo boxes are grayed out when their value is not used. Note that vectors can be used for orientation as well as scaling, so it will not be grayed out unless you uncheck orient.
/cvsroot/ParaView3/ParaView3/Qt/Components/pqGlyphPanel.cxx,v <-- pqGlyphPanel.cxx
/cvsroot/ParaView3/ParaView3/Qt/Components/pqGlyphPanel.h,v <-- pqGlyphPanel.h
new revision: 1.3; previous revision: 1.2 |
(0015410)
Alan Scott
2009-02-25 20:46
Almost. When you are glyphing by vectors, scalars is grayed out. But, if you are glyphing by scalars, vectors are still selectable. |
(0015440)
Ken Moreland
2009-02-26 18:51
Nope, that behavior is correct. As I said in the previous note, vectors are used for BOTH scaling AND orientation. If you set the scaling to scalars or off AND turn off the Orient flag, then the vectors will be grayed out. |
(0015503)
Alan Scott
2009-03-02 21:45
Ah, Ken was correct.
Tested client/remote server. |
