(0012059)
Alan Scott
2008-05-21 22:37
Strange. The cameras are now correct from a rotation standpoint, but not from a scale standpoint.
* Open disk_out_ref.exo.
* Split window horizontally.
* Make the right object parallel projection.
* Split the left AND right window vertically.
* Make disk_out_ref visible in all, using the eyeball.
* link all the windows.
* Use the right mouse button. The parallel objects move closer/further apart together, the orthogonal ones also move together. The parallel and orthogonal do not.
Tested client/server. |
(0012067)
Utkarsh Ayachit
2008-05-22 07:40
Linking parallel and perspective views is not supported. All linked view must have same projection type. If I am not mistaken, the bug was referring to the linking within the views that comprise the comparative view itself, in other words no explicit linking needed to be done by the user. |
(0012073)
Alan Scott
2008-05-22 20:23
Thanks.
Closed. Tested client/server. |
