MantisBT - ParaView | |||||
View Issue Details | |||||
0007614 | ParaView | (No Category) | public | 2008-09-05 10:41 | 2016-08-12 09:57 |
Reporter | Stephane P | ||||
Priority | normal | Severity | major | Reproducibility | always |
Product Version | |||||
Project | ParaViS | ||||
Topic Name | |||||
Type | |||||
Summary | 0007614: "select points on" and "select cells on" does not work with tiled displays | ||||
Description | When using the selection mechanism, one cannot select points or surfaces is paraview uses a tiled display. Selecting points or cells through works well. if the user activates the "select points on" or "select cells on" mode, after dragging over the region to select, the tiled display displays strange colors once before displaying the good colors back, and nothing is ever selected. | ||||
Steps To Reproduce | |||||
Relationships | |||||
Attached Files | |||||
Issue History | |||||
2008-09-05 10:41 | Stephane P | New Issue | |||
2009-02-17 13:19 | Utkarsh Ayachit | Category | Development => 3.8 | ||
2009-05-13 13:41 | Utkarsh Ayachit | Target Version | => 3.8 | ||
2010-11-26 13:50 | David Partyka | Assigned To | => Utkarsh Ayachit | ||
2010-11-26 13:50 | David Partyka | Status | backlog => tabled | ||
2011-06-16 13:10 | Zack Galbreath | Category | => (No Category) | ||
2011-06-23 11:44 | Utkarsh Ayachit | Project | => ParaViS | ||
2016-08-12 09:57 | Kitware Robot | Note Added: 0037591 | |||
2016-08-12 09:57 | Kitware Robot | Status | expired => closed | ||
Notes | |||||
