MantisBT - ParaView | |||||
View Issue Details | |||||
0007780 | ParaView | (No Category) | public | 2008-10-06 16:24 | 2009-02-17 21:07 |
Reporter | David Doria | ||||
Priority | normal | Severity | minor | Reproducibility | always |
Status | closed | Resolution | won't fix | ||
Product Version | |||||
Project | |||||
Topic Name | |||||
Type | |||||
Summary | 0007780: Extract Selection Filter does not copy Data Arrays | ||||
Description | I'm trying to "crop" 3d points with an associated RGB data array. I use the "select points through" tool to the select the region I want to crop. Then I use the "extract selection" filter. This almost achieves the goal, except the corresponding colors in the RGB data array are not copied to the selection, so the cropped points are now a uniform color, rather than colored as they were in the original data set. | ||||
Steps To Reproduce | |||||
Relationships | |||||
Attached Files | test.vtk (3,503) 2008-10-06 16:24 https://www.vtk.org/Bug/file/6751/test.vtk extracted.vtk (996) 2008-10-06 16:24 https://www.vtk.org/Bug/file/6752/extracted.vtk | ||||
Issue History | |||||
2008-10-06 16:24 | David Doria | New Issue | |||
2008-10-06 16:24 | David Doria | File Added: test.vtk | |||
2008-10-06 16:24 | David Doria | File Added: extracted.vtk | |||
2008-10-06 16:25 | David Doria | Note Added: 0013734 | |||
2008-10-18 16:00 | David Doria | Note Added: 0013899 | |||
2009-02-17 14:10 | Utkarsh Ayachit | Note Added: 0015050 | |||
2009-02-17 14:10 | Utkarsh Ayachit | Status | backlog => @80@ | ||
2009-02-17 14:10 | Utkarsh Ayachit | Resolution | open => won't fix | ||
2009-02-17 14:10 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit | ||
2009-02-17 21:07 | Alan Scott | Note Added: 0015114 | |||
2009-02-17 21:07 | Alan Scott | Status | @80@ => closed | ||
Notes | |||||
