MantisBT - ParaView | |||||
View Issue Details | |||||
0008071 | ParaView | (No Category) | public | 2008-11-10 06:38 | 2016-08-12 09:57 |
Reporter | dh | ||||
Priority | normal | Severity | crash | Reproducibility | always |
Product Version | |||||
Project | |||||
Topic Name | |||||
Type | |||||
Summary | 0008071: crash when reading vrml 2 file | ||||
Description | paraview crashes reguraly when reading vrml2 files. Example is attached. > script Script started, file is typescript sh-3.2$ gdb /tmp/paraview-3.4.0-Linux-x86_64/bin/paraview GNU gdb Red Hat Linux (6.5-37.el5_2.2rh) Copyright (C) 2006 Free Software Foundation, Inc. GDB is free software, covered by the GNU General Public License, and you are welcome to change it and/or distribute copies of it under certain conditions. Type "show copying" to see the conditions. There is absolutely no warranty for GDB. Type "show warranty" for details. This GDB was configured as "x86_64-redhat-linux-gnu"...(no debugging symbols found) Using host libthread_db library "/lib64/libthread_db.so.1". (gdb) run Starting program: /tmp/paraview-3.4.0-Linux-x86_64/bin/paraview (no debugging symbols found) (no debugging symbols found) Program received signal SIGSEGV, Segmentation fault. Cannot remove breakpoints because program is no longer writable. It might be running in another process. Further execution is probably impossible. 0x00002b146c9cb4b4 in ?? () (gdb) Quit (gdb) quit The program is running. Exit anyway? (y or n) y sh-3.2$ exit exit Script done, file is typescript | ||||
Steps To Reproduce | |||||
Relationships | |||||
Attached Files | Explorer.k.small.wrl.gz (1,214,359) 2008-11-10 06:38 https://www.vtk.org/Bug/file/6839/Explorer.k.small.wrl.gz | ||||
Issue History | |||||
2008-11-10 06:38 | dh | New Issue | |||
2008-11-10 06:38 | dh | File Added: Explorer.k.small.wrl.gz | |||
2009-02-17 14:56 | Utkarsh Ayachit | Category | 3.4 => 3.8 | ||
2009-05-13 13:41 | Utkarsh Ayachit | Target Version | => 3.8 | ||
2011-06-16 13:10 | Zack Galbreath | Category | => (No Category) | ||
2016-08-12 09:57 | Kitware Robot | Note Added: 0037602 | |||
2016-08-12 09:57 | Kitware Robot | Status | expired => closed | ||
2016-08-12 09:57 | Kitware Robot | Resolution | open => moved | ||
2016-08-12 09:57 | Kitware Robot | Assigned To | => Kitware Robot |
Notes | |||||
