(0015085)
Utkarsh Ayachit
2009-02-17 16:41
Need more information. Can you reproduce the crash with a simple plugin that you can share? |
(0015480)
Benjamin Schindler
2009-03-02 03:50
I have created a simple plugin quite some time ago - that plugin did absolutely nothing. All it had is a filter class which showed up under the filters menu. But the filter code was in all empty.
I tried the same on two different machines, both running gentoo and paraview does not crash there.
So this seems like a distro specific thing - I'm running:
bschindl@macke /local/bschindler/animations/smooth $ uname -a
Linux macke 2.6.18-92.1.22.el5 #1 SMP Fri Dec 5 09:29:46 EST 2008 i686 i686 i386 GNU/Linux
Note, the crash does not happen, when I compile the plugin with PARAVIEW_EXTRA_EXTERNAL_PLUGIN
I'll try to create such a plugin, but it will look like the most basic textbook example |
(0016755)
Benjamin Schindler
2009-06-25 11:07
okay, I was able to figure out a little bit. It crashes in line 312 of vtkClinetServerInterpreter.cxx
I looked at the NewInstanceFunctions array in this->Internal and found the following entries:
vtkClientServerID)) 0x2251540 <vtkCommonCS_NewInstance>
vtkClientServerID)) 0x75a7790 <vtkFilteringCS_NewInstance>
vtkClientServerID)) 0xc973f0 <vtkGenericFilteringCS_NewInstance>
vtkClientServerID)) 0x68c6e40 <vtkImagingCS_NewInstance>
vtkClientServerID)) 0x703f5b0 <vtkInfovisCS_NewInstance>
vtkClientServerID)) 0x78d89f0 <vtkGraphicsCS_NewInstance>
vtkClientServerID)) 0x6c9c6f0 <vtkIOCS_NewInstance>
vtkClientServerID)) 0x218f020 <vtkRenderingCS_NewInstance>
vtkClientServerID)) 0x18ddb60 <vtkVolumeRenderingCS_NewInstance>
vtkClientServerID)) 0x18aa790 <vtkHybridCS_NewInstance>
vtkClientServerID)) 0x9275a40 <vtkWidgetsCS_NewInstance>
vtkClientServerID)) 0x659aa40 <vtkParallelCS_NewInstance>
vtkClientServerID)) 0xa31560 <vtkPVServerCommonCS_NewInstance>
vtkClientServerID)) 0x37cfdb0 <vtkPVFiltersCS_NewInstance>
vtkClientServerID)) 0x776030 <vtkXdmfCS_NewInstance>
vtkClientServerID)) 0x332b870 <vtkPVServerManager_NewInstance>
vtkClientServerID)) 0x363fc20 <CSCS_Common_SMPlugin_NewInstance>
vtkClientServerID)) 0x36c51a0 <CSCS_ESPHI_SMPlugin_NewInstance>
vtkClientServerID)) 0x3709fb0 <CSCS_H5Part_SMPlugin_NewInstance>
vtkClientServerID)) 0x64e6520 <CSCS_PointSprite_GUIPlugin_NewInstance>
vtkClientServerID)) 0x30bdc90 <Moments_NewInstance>
elem[21]: $23 = (int (*)(vtkClientServerInterpreter *, const char *, vtkClientServerID)) 0x90ceef0
vtkClientServerID)) 0x62d7ef0 <PrismClientPlugin_NewInstance>
vtkClientServerID)) 0x5d76340 <PrismServerPlugin_NewInstance>
vtkClientServerID)) 0x380d5f0 <sphvis_NewInstance>
See that elem21 - it was not able to resolve it. And it crashes, because I'm trying to instantiate something from sphvis_NewInstance. I checked - it's the first time the iterator needs to loop over item 21 and this is where it crashes. I have yet to figure out which plugin is not loaded/missing.
I'll report back once I know more |
(0016756)
Benjamin Schindler
2009-06-25 11:42
Okay, I figured something:
The PrismClientPlugin got loaded twice. I set a breakpoint on
vtkClientServerInterpreter::AddNewInstanceFunction
and item 21 was PrismClientPlugin which was followed by itself once again
I surely hope this helps you fix this
For completeness, I attach the output of my debugging session:
Breakpoint 1, vtkClientServerInterpreter::AddNewInstanceFunction (this=0x9413dc0,
f=0x41031a0 <CSCS_ESPHI_SMPlugin_NewInstance>)
at /home/bschindl/software/pv-meshless/Utilities/VTKClientServer/vtkClientServerInterpreter.cxx:748
748 }
(gdb) c
Continuing.
f=0x5518fb0 <CSCS_H5Part_SMPlugin_NewInstance>)
748 }
(gdb) c
Continuing.
f=0x4752520 <CSCS_PointSprite_GUIPlugin_NewInstance>)
748 }
(gdb) c
Continuing.
Breakpoint 1, vtkClientServerInterpreter::AddNewInstanceFunction (this=0x9413dc0, f=0x4166c90 <Moments_NewInstance>)
748 }
(gdb) c
Continuing.
f=0x4182ef0 <PrismClientPlugin_NewInstance>)
748 }
(gdb) c
Continuing.
748 }
(gdb) c
Continuing.
f=0x60e6340 <PrismServerPlugin_NewInstance>)
748 }
(gdb) c
Continuing.
Breakpoint 1, vtkClientServerInterpreter::AddNewInstanceFunction (this=0x9413dc0, f=0x6ece5f0 <sphvis_NewInstance>)
748 }
(gdb) c
Cheers
Benjamin |
(0017191)
Alan Scott
2009-08-24 16:30
Resolving, since we don't think this is ParaView's problem. If you feel otherwise, please re-open it. |
