(0016235)
Alan Scott
2009-04-28 21:00
OK, I just learned a bit more. This is an option, found under the Display tab. You can say "Use Data Array", then Points (Magnitude).
I would like to propose that this be the default. The other option would be to make this selection "sticky", such that a user has to set it once.
Since I suspect this is easy, lets try to get it into 3.6? |
(0016254)
Ken Moreland
2009-04-29 15:49
I concur that this should be the default. I thought at one point that it was. |
(0016274)
Utkarsh Ayachit
2009-05-01 11:17
Charting views now use better defaults. Adding new filter to add arc-length to plot-over-line filter.
/cvsroot/ParaView3/ParaView3/Qt/Components/Resources/UI/pqBarChartDisplayPanel.ui,v <-- Qt/Components/Resources/UI/pqBarChartDisplayPanel.ui
new revision: 1.4; previous revision: 1.3
/cvsroot/ParaView3/ParaView3/Qt/Components/Resources/UI/pqLineChartDisplayPanel.ui,v <-- Qt/Components/Resources/UI/pqLineChartDisplayPanel.ui
/cvsroot/ParaView3/ParaView3/Qt/Components/pqBarChartDisplayPanel.cxx,v <-- Qt/Components/pqBarChartDisplayPanel.cxx
new revision: 1.3; previous revision: 1.2
/cvsroot/ParaView3/ParaView3/Qt/Components/pqBarChartDisplayPanel.h,v <-- Qt/Components/pqBarChartDisplayPanel.h
/cvsroot/ParaView3/ParaView3/Qt/Components/pqBarChartDisplayProxyEditor.cxx,v <-- Qt/Components/pqBarChartDisplayProxyEditor.cxx
new revision: delete; previous revision: 1.11
/cvsroot/ParaView3/ParaView3/Qt/Components/pqBarChartDisplayProxyEditor.h,v <-- Qt/Components/pqBarChartDisplayProxyEditor.h
new revision: delete; previous revision: 1.5
/cvsroot/ParaView3/ParaView3/Qt/Components/pqLineChartDisplayPanel.cxx,v <-- Qt/Components/pqLineChartDisplayPanel.cxx
new revision: 1.5; previous revision: 1.4
/cvsroot/ParaView3/ParaView3/Qt/Components/pqLineChartDisplayPanel.h,v <-- Qt/Components/pqLineChartDisplayPanel.h
new revision: 1.2; previous revision: 1.1
/cvsroot/ParaView3/ParaView3/Qt/Core/CMakeLists.txt,v <-- Qt/Core/CMakeLists.txt
new revision: 1.105; previous revision: 1.104
/cvsroot/ParaView3/ParaView3/Qt/Core/pqChartRepresentation.cxx,v <-- Qt/Core/pqChartRepresentation.cxx
initial revision: 1.1
/cvsroot/ParaView3/ParaView3/Qt/Core/pqChartRepresentation.h,v <-- Qt/Core/pqChartRepresentation.h
/cvsroot/ParaView3/ParaView3/Qt/Core/pqStandardViewModules.cxx,v <-- Qt/Core/pqStandardViewModules.cxx
new revision: 1.23; previous revision: 1.22
/cvsroot/ParaView3/ParaView3/Servers/Filters/CMakeLists.txt,v <-- Servers/Filters/CMakeLists.txt
new revision: 1.192; previous revision: 1.191
/cvsroot/ParaView3/ParaView3/Servers/Filters/vtkAppendArcLength.cxx,v <-- Servers/Filters/vtkAppendArcLength.cxx
initial revision: 1.1 |
(0016319)
Alan Scott
2009-05-06 16:49
Excellent.
Tested local client. |
