MantisBT - ParaView | |||||
View Issue Details | |||||
0009288 | ParaView | Bug | public | 2009-07-20 22:13 | 2009-07-31 19:44 |
Reporter | Alan Scott | ||||
Priority | high | Severity | major | Reproducibility | always |
Status | closed | Resolution | fixed | ||
Product Version | |||||
Target Version | 3.6.2 | Fixed in Version | 3.6.2 | ||
Project | |||||
Topic Name | |||||
Type | |||||
Summary | 0009288: Display panel settings aren't used when a filter is created. | ||||
Description | This is a problem for particle physics folks, and is really confusing - so I am marking it as urgent. * ParaView 3.6.0. Local server. XP. * Open can.exo. Apply. * On the display tab, change Translate X to 10. Click in the window, make the can move. * Filter/ Alphabetical/ Extract Block. Choose Unnamed block ID: 1. Apply. >> Bug - notice that the can segment has not offset like the original. - Go to the Display tab, and notice that the Translate X is correctly 10. This did not take effect. - Click on Selectable, and the can will jump to the correct position. - This also happens with point size. if you set it to 1, then make a new filter, point size won't take effect until you click something. It should automagically happen. | ||||
Steps To Reproduce | |||||
Relationships | |||||
Attached Files | |||||
Issue History | |||||
2009-07-20 22:13 | Alan Scott | New Issue | |||
2009-07-31 11:34 | Utkarsh Ayachit | Status | backlog => tabled | ||
2009-07-31 11:34 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit | ||
2009-07-31 11:37 | Utkarsh Ayachit | Note Added: 0017037 | |||
2009-07-31 11:37 | Utkarsh Ayachit | Status | tabled => @80@ | ||
2009-07-31 11:37 | Utkarsh Ayachit | Fixed in Version | => 3.6.2 | ||
2009-07-31 11:37 | Utkarsh Ayachit | Resolution | open => fixed | ||
2009-07-31 19:44 | Alan Scott | Note Added: 0017046 | |||
2009-07-31 19:44 | Alan Scott | Status | @80@ => closed |
Notes | |||||
