MantisBT - ParaView | |||||
View Issue Details | |||||
0009298 | ParaView | Bug | public | 2009-07-22 12:26 | 2009-12-09 21:53 |
Reporter | David Partyka | ||||
Priority | normal | Severity | major | Reproducibility | always |
Status | closed | Resolution | won't fix | ||
Product Version | 3.6 | ||||
Project | |||||
Topic Name | |||||
Type | |||||
Summary | 0009298: Help QT assistant fails to launch. | ||||
Description | If you you install a ParaView 3.6 binary and then launch paraview by clicking on paraview.exe in c:\Program Files\ParaView-3.6.1\bin\ and then try to run help from either the Help Menu or hitting F1, the QT assistant will fail to launch. This also happens if you launch paraview.exe from the command line after cd'ing to c:\Program Files\ParaView-3.6.1\bin\ If you run paraview from the installed shortcut all is well. | ||||
Steps To Reproduce | |||||
Additional Information | I blame pqClientFindDoc | ||||
Relationships | |||||
Attached Files | |||||
Issue History | |||||
2009-07-22 12:26 | David Partyka | New Issue | |||
2009-07-22 17:05 | David Partyka | Note Added: 0016942 | |||
2009-12-09 10:37 | Utkarsh Ayachit | Note Added: 0018737 | |||
2009-12-09 10:37 | Utkarsh Ayachit | Status | backlog => @80@ | ||
2009-12-09 10:37 | Utkarsh Ayachit | Resolution | open => won't fix | ||
2009-12-09 10:37 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit | ||
2009-12-09 21:53 | Alan Scott | Note Added: 0018779 | |||
2009-12-09 21:53 | Alan Scott | Status | @80@ => closed |
Notes | |||||
