MantisBT - ParaView | |||||
View Issue Details | |||||
0009353 | ParaView | Bug | public | 2009-08-03 21:05 | 2009-08-13 22:27 |
Reporter | Alan Scott | ||||
Assigned To | Ken Moreland | ||||
Priority | normal | Severity | minor | Reproducibility | always |
Status | closed | Resolution | won't fix | ||
Product Version | |||||
Target Version | 3.8 | Fixed in Version | |||
Project | |||||
Topic Name | |||||
Type | |||||
Summary | 0009353: csv file writes incorrect data from spreadsheet when only showing selections | ||||
Description | I believe that the csv file writer should only show the spreadsheet data that is visible when we have "Show only selected elements" checked. * ParaView XP, local server, 3.6.0. * Open Can. All variables on. Apply. * Select a cell. * Split vertical. Spreadsheet. * Display tab, select "Show only selected elements". Be sure that the spreadsheet is highlighted. * File/ Save Data. Save as a .csv file. <<Bug>> - all of the points or cells will be written out. Only the ones that you have selected should be. | ||||
Steps To Reproduce | |||||
Relationships | |||||
Attached Files | |||||
Issue History | |||||
2009-08-03 21:05 | Alan Scott | New Issue | |||
2009-08-04 12:47 | Ken Moreland | Note Added: 0017056 | |||
2009-08-04 12:47 | Ken Moreland | Status | backlog => @80@ | ||
2009-08-04 12:47 | Ken Moreland | Resolution | open => won't fix | ||
2009-08-04 12:47 | Ken Moreland | Assigned To | => Ken Moreland | ||
2009-08-13 22:27 | Alan Scott | Note Added: 0017124 | |||
2009-08-13 22:27 | Alan Scott | Status | @80@ => closed |
Notes | |||||
