MantisBT - ParaView | |||||
View Issue Details | |||||
0009453 | ParaView | Bug | public | 2009-08-26 06:49 | 2009-09-22 22:06 |
Reporter | Bart Janssens | ||||
Assigned To | Zhanping Liu | ||||
Priority | high | Severity | major | Reproducibility | always |
Status | closed | Resolution | fixed | ||
Product Version | Development | ||||
Target Version | 3.6.2 | Fixed in Version | |||
Project | |||||
Topic Name | |||||
Type | |||||
Summary | 0009453: vtkConvexPointSet::EvaluatePosition does not correctly set the interpolation weights | ||||
Description | When plotting over a line that encounters vtkConvexPointSet cells, the Plot Over Line filter gives incorrect results. This is caused by incorrect weights being set by vtkConvexPointSet::EvaluatePosition, where the weights relative to all sub-tetrahedra are set, instead of just the closest one. This results in a set of weights that can not give correct interpolation results in filters like Plot Over Line. A patch to fix this is attached. | ||||
Steps To Reproduce | |||||
Relationships | |||||
Attached Files | vtkConvexPointSet-weights.diff (1,721) 2009-08-26 06:49 https://www.vtk.org/Bug/file/7424/vtkConvexPointSet-weights.diff | ||||
Issue History | |||||
2009-08-26 06:49 | Bart Janssens | New Issue | |||
2009-08-26 06:49 | Bart Janssens | File Added: vtkConvexPointSet-weights.diff | |||
2009-09-17 10:42 | Zhanping Liu | Assigned To | => Zhanping Liu | ||
2009-09-17 10:42 | Zhanping Liu | Status | backlog => tabled | ||
2009-09-21 15:45 | Alan Scott | Note Added: 0017682 | |||
2009-09-21 15:45 | Alan Scott | Priority | normal => high | ||
2009-09-21 15:45 | Alan Scott | Target Version | => 3.6.2 | ||
2009-09-22 15:06 | Zhanping Liu | Note Added: 0017708 | |||
2009-09-22 15:07 | Zhanping Liu | Status | tabled => @80@ | ||
2009-09-22 22:01 | Alan Scott | Note Added: 0017718 | |||
2009-09-22 22:01 | Alan Scott | Status | @80@ => @20@ | ||
2009-09-22 22:01 | Alan Scott | Resolution | open => reopened | ||
2009-09-22 22:06 | Alan Scott | Note Added: 0017720 | |||
2009-09-22 22:06 | Alan Scott | Status | @20@ => closed | ||
2009-09-22 22:06 | Alan Scott | Resolution | reopened => fixed |
Notes | |||||
