MantisBT - ParaView | |||||
View Issue Details | |||||
0009628 | ParaView | Bug | public | 2009-10-01 02:50 | 2016-08-12 09:57 |
Reporter | Sven Buijssen | ||||
Priority | normal | Severity | crash | Reproducibility | always |
Product Version | 3.6 | ||||
Project | |||||
Topic Name | |||||
Type | |||||
Summary | 0009628: Applying Loop Subdivision filter to triangulated surface of several geometry-appended box sources causes segfault | ||||
Description | Put 6 box sources next to/on top of each other like bricks Select all of them and apply Append Geometry Filter Apply Clean to Grid filter Apply Extract Surface filter Triangulate the surface to fulfill input requirements for Loop Subdivision filter Apply Loop Subdivision filter PV 3.6.1: will segfault immediately, regardless the number of subdivision setting. PV 3.7 cvs as of today: will create a degenerated mesh for #subdivisions = 1 and segfault for #subdivisions > 1 | ||||
Steps To Reproduce | |||||
Additional Information | To reproduce easily load the attached state file and apply Loop Subdivision filter with #subdivisions = 1 and > 1. | ||||
Relationships | |||||
Attached Files | 7boxes-crash-on-loopsubdivide.pvsm (375,736) 2009-10-01 02:50 https://www.vtk.org/Bug/file/7504/7boxes-crash-on-loopsubdivide.pvsm | ||||
Issue History | |||||
2009-10-01 02:50 | Sven Buijssen | New Issue | |||
2009-10-01 02:50 | Sven Buijssen | File Added: 7boxes-crash-on-loopsubdivide.pvsm | |||
2010-06-10 15:36 | Sven Buijssen | Note Added: 0020984 | |||
2016-08-12 09:57 | Kitware Robot | Note Added: 0037723 | |||
2016-08-12 09:57 | Kitware Robot | Status | expired => closed | ||
2016-08-12 09:57 | Kitware Robot | Resolution | open => moved | ||
2016-08-12 09:57 | Kitware Robot | Assigned To | => Kitware Robot |
Notes | |||||
