MantisBT - ParaView | |||||
View Issue Details | |||||
0009708 | ParaView | Bug | public | 2009-10-13 16:14 | 2016-08-12 09:57 |
Reporter | Burlen | ||||
Priority | normal | Severity | minor | Reproducibility | always |
Product Version | Development | ||||
Project | |||||
Topic Name | |||||
Type | |||||
Summary | 0009708: When loading from state file a time series with more than 100 steps the spin box in the ui would only go up to 99. | ||||
Description | When loading from state file a time series with more than 100 steps the spin box in the ui would only go up to 99. The animation inspector could be used to select any step though. to reproduce on may take a single vtk file and make a couple hundred sym links to it. for i in `seq 1 200`; do ln -s ./test.vtk ./f_$i.vtk; done Then open this series in PV, set to some one of the steps save a state file, close PV, open PV and load the state file. | ||||
Steps To Reproduce | |||||
Relationships | |||||
Attached Files | |||||
Issue History | |||||
2009-10-13 16:14 | Burlen | New Issue | |||
2016-08-12 09:57 | Kitware Robot | Note Added: 0037733 | |||
2016-08-12 09:57 | Kitware Robot | Status | expired => closed | ||
2016-08-12 09:57 | Kitware Robot | Resolution | open => moved | ||
2016-08-12 09:57 | Kitware Robot | Assigned To | => Kitware Robot |
Notes | |||||
