MantisBT - ParaView | |||||
View Issue Details | |||||
0009828 | ParaView | (No Category) | public | 2009-11-03 08:49 | 2016-08-12 09:57 |
Reporter | Christine Corbett Moran | ||||
Priority | normal | Severity | feature | Reproducibility | always |
Product Version | |||||
Project | |||||
Topic Name | |||||
Type | |||||
Summary | 0009828: If there are a numer of file list domains for a given reader, the main data file is decided be the alphabetically first name | ||||
Description | I found that when one has specified multiple file list domains in the server XML, ParaView decides which one is the "main" file (i.e. the one specified with the --data= flag at the command line or the first file selected in a reader) by the name of the string attribute which is a file list domain which is alphabetically first. It would be nice if there was a way to manually specify which file should be the main file, or if this behavior was more explicit. | ||||
Steps To Reproduce | |||||
Relationships | |||||
Attached Files | |||||
Issue History | |||||
2009-11-03 08:49 | Christine Corbett Moran | New Issue | |||
2009-12-09 14:49 | Berk Geveci | Project | @3@ => ParaView | ||
2011-06-16 13:10 | Zack Galbreath | Category | => (No Category) | ||
2016-08-12 09:57 | Kitware Robot | Note Added: 0037742 | |||
2016-08-12 09:57 | Kitware Robot | Status | expired => closed | ||
2016-08-12 09:57 | Kitware Robot | Resolution | open => moved | ||
2016-08-12 09:57 | Kitware Robot | Assigned To | => Kitware Robot |
Notes | |||||
