MantisBT - ParaView
View Issue Details
0009881ParaViewFeaturepublic2009-11-10 22:162016-08-12 09:57
Alan Scott
Kitware Robot
normalminoralways
closedmoved
5.1
TBD
incorrect functionality
0009881: Feature - cleaner backface cull with wireframe
The current option to cull backfaces (under the Display tab) is much better than we had, but we should also have a form of wireframe that doesn't display wires that are behind the object. Here is a screenshot of Paraview, culling backface lines, and EnSight's default wireframe. EnSight's looks a lot nicer.
No tags attached.
related to 0002703closed Utkarsh Ayachit SNL: enhancement: Hidden line removal for backface surfaces
png paraviewScreenshot.png (44,185) 2009-11-10 22:16
https://www.vtk.org/Bug/file/7647/paraviewScreenshot.png
png
png ensightScreenshot.png (89,518) 2009-11-10 22:17
https://www.vtk.org/Bug/file/7648/ensightScreenshot.png
png
jpg goodWireframe.jpg (213,927) 2016-02-12 15:32
https://www.vtk.org/Bug/file/10037/goodWireframe.jpg
jpg
jpg goodWireframe2.jpg (219,188) 2016-02-12 15:36
https://www.vtk.org/Bug/file/10038/goodWireframe2.jpg
jpg
Issue History
2009-11-10 22:16Alan ScottNew Issue
2009-11-10 22:16Alan ScottFile Added: paraviewScreenshot.png
2009-11-10 22:17Alan ScottFile Added: ensightScreenshot.png
2010-01-18 22:36Alan ScottRelationship addedhas duplicate 0002703
2010-01-19 12:35Alan ScottRelationship deletedhas duplicate 0002703
2010-01-19 12:35Alan ScottRelationship addedrelated to 0002703
2011-06-16 13:10Zack GalbreathCategoryFeature Request => Feature
2015-12-23 22:07Alan ScottNote Added: 0035609
2015-12-23 22:07Alan ScottStatusexpired => backlog
2015-12-23 22:07Alan ScottResolutionopen => reopened
2015-12-23 22:07Alan ScottProject => TBD
2015-12-23 22:07Alan ScottType => incorrect functionality
2015-12-23 22:07Alan ScottTarget Version => 5.1
2016-02-12 15:29Alan ScottNote Added: 0035733
2016-02-12 15:32Alan ScottNote Edited: 0035733bug_revision_view_page.php?bugnote_id=35733#r1522
2016-02-12 15:32Alan ScottFile Added: goodWireframe.jpg
2016-02-12 15:36Alan ScottFile Added: goodWireframe2.jpg
2016-08-12 09:57Kitware RobotNote Added: 0037747
2016-08-12 09:57Kitware RobotStatusbacklog => closed
2016-08-12 09:57Kitware RobotResolutionreopened => moved
2016-08-12 09:57Kitware RobotAssigned To => Kitware Robot
Notes
(0035609)
Alan Scott
2015-12-23 22:07
I still really, really want this. Note that it isn't just deleting backfaces. It is drawing the object in the background color, with wireframe on top. You can see this with the block behind the can. We don't want to see the block at all through the can - including front face lines.
(0035733)
Alan Scott
2016-02-12 15:29
(edited on: 2016-02-12 15:32)
Adding an image of what I want, created with ParaView. I did the following (which is not reasonable for a user to do):
* Turn lighting kit off.
* Read in Can.exo. Solid color. Edit color. Make color the background. For default, this is 81, 87, 110. Surface. Apply.
* Read in the can again (or use the Pass Arrays filter).
* Wireframe.
* Make sure both filters are turned on.
* I had to play with the translation part of transform, bringing the lines forward slightly (-0.06)
I am attaching a screenshot of what this looks like.
(0037747)
Kitware Robot
2016-08-12 09:57
Resolving issue as `moved`.
