MantisBT - ParaView
View Issue Details
0009984ParaViewBugpublic2009-12-01 11:222009-12-02 20:18
Utkarsh Ayachit
Utkarsh Ayachit
normalminorhave not tried
closedfixed
3.83.8
0009984: Issue with Implicit Plane Widget
* Create Wavelet
* Change Extent to (0, 1, 0, 1, 0, 1)
* Apply
* Create Slice filter
* The implicit plane widget's bounds are not correct.
No tags attached.
has duplicate 0009591closed Utkarsh Ayachit Clip bounding box is in wrong location.
Issue History
2009-12-01 11:22Utkarsh AyachitNew Issue
2009-12-01 17:05Utkarsh AyachitStatusbacklog => tabled
2009-12-01 17:05Utkarsh AyachitAssigned To => Utkarsh Ayachit
2009-12-01 17:06Utkarsh AyachitNote Added: 0018632
2009-12-01 17:06Utkarsh AyachitStatustabled => @80@
2009-12-01 17:06Utkarsh AyachitFixed in Version => 3.8
2009-12-01 17:06Utkarsh AyachitResolutionopen => fixed
2009-12-02 14:15Utkarsh AyachitRelationship addedhas duplicate 0009591
2009-12-02 20:18Alan ScottNote Added: 0018675
2009-12-02 20:18Alan ScottStatus@80@ => closed
Notes
(0018632)
Utkarsh Ayachit
2009-12-01 17:06
When bounds of the data were same as the default value for
the PlaceWidget property, it wasn't getting pushed. Fixed that by changing
default to initialized.
/cvsroot/ParaView3/ParaView3/Servers/ServerManager/Resources/rendering.xml,v <-- Servers/ServerManager/Resources/rendering.xml
new revision: 1.379; previous revision: 1.378
(0018675)
Alan Scott
2009-12-02 20:18
Tested local server. Also tested with clip.
