0010404 | ParaView | Bug | public | 2010-03-10 19:14 | 2016-08-12 09:58 | ||||
Summary | 0010404: TextureMapToSphere reverses textures | ||||||||
Description | I have a user that wants to map the world to a sphere. ParaView 3.6.2, XP, local server. * Sources/ SuperQuadric. Theta resolution == 128. Phi Resolution = 128. * Turn off Toroidal. * Apply. * On the Display tab, Apply Texture. * Use the world map, found at http://www.oera.net/How2/PlanetTexs/EarthMap_2500x1250.jpg. [^] [^] (Enter this on the Display tab) * Notice that the earth looks good. * Filters/ Alphabetical/ TextureMapToSphere. * On the Display tab, Apply Texture. * Notice that the earth looks reversed. We are speculating this is because the original developer of this filter wanted to be able to wrap the texture on a sphere, and that the user then moved the eye INSIDE of the sphere - thus making the sphere the 3d window background. Thus, please make a user selectable option allowing the user to reverse the texture if desired. | ||||||||
(0031496) Alan Scott (manager) 2013-08-26 19:14 |
It is also mirrored. Once again, this is incorrect. |
(0031497) Alan Scott (manager) 2013-08-26 19:14 |
this is needed by a user. |
(0037795) Kitware Robot (administrator) 2016-08-12 09:58 |
2010-03-10 19:14 | Alan Scott | New Issue | |
2010-03-10 19:45 | Alan Scott | Description Updated | |
2013-08-26 19:14 | Alan Scott | Note Added: 0031496 | |
2013-08-26 19:14 | Alan Scott | Note Added: 0031497 | |
2013-08-26 19:14 | Alan Scott | Status | expired => backlog |
2013-08-26 19:14 | Alan Scott | Resolution | open => reopened |
2016-08-12 09:58 | Kitware Robot | Note Added: 0037795 | |
2016-08-12 09:58 | Kitware Robot | Resolution | reopened => moved |
